42/40 tire pressure causes problems?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lenjack, Jul 29, 2007.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I've been using 42/40 front/rear pressures on my '07 since new...7800 miles. Has anyone noticed if this causes accelerated wear in the tread center over the life of the tire? Original Integrity's.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    No, it should reduce wear significantly.
  3. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  4. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I run about 42/40 and have over 38,000 on the original Goodyear OEMS, still 1/3 to 1/2 tread and it appears evenly worn. I do 99% highway driving. I only rotate front to back every 10K or so.
  5. lenjack
    804
    114
    Pennsylvania USA
    Thanks...I'll find something else to worry about.
  6. p626808
    p626808 New Member
    292
    <div class='quotetop'>QUOTE(lenjack @ Jul 29 2007, 02:21 PM) [snapback]487128[/snapback]</div>
    Been at 42/40 for 114K miles now..
    Have 76K on my hydroedges..
    And you know what.. it is the edges of the tire that are wearing the fastest..
    Probably because of to many high speed turns..lol
    Anyway.. no problem...
