42 mph?
Discussion in 'Gen 5 Prius Main Forum' started by harshfie, May 9, 2024.
Tags:
  1. harshfie
    harshfie Junior Member
    Virginia, USA
    I owned a 2007 Prius for 17 years. I was well aware that the ICE would always start running if I got my speed up to 42 mph.
    I recently replaced my 2007 with a 2024 XLE. I am not detecting anything special above 42 mph. Can the ICE stay off above 42 mph? My dashboard can still have the EV mode light on well above 50 mph. What has changed?
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,362
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Larger battery and more powerful motor. I think the new cutoff point for the regular(non-Prime) Prius is around 60mph, maybe 65. Granted, EV mode doesn't last long at those speeds since you're burning through electricity at a pretty brisk pace, but you might get a minute or three of EV before the ICE kicks in, depending on the slope and wind conditions. For me, the conditions have been pretty rare for it to happen, but I've had the ICE shut off at 55mph a handful of times on a flat road when I had a decent tailwind.
    GcinFl likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,030
    5,295
    Pacific Northwest, USA
    The change is a much bigger hybrid battery pack and a much bigger electric motor...
  4. ChapmanF
    18,526
    and also MG1 can spin higher RPMs without flying apart, which was the original reason the engine had to start spinning above 41 MPH.
    reallyreal, AndersOne and PriusCamper like this.
  5. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Coincidentally the 42 MPH speed was likely to have been selected as the cut off point for EV running because it is equal to 65 KPH in the Japanese market.
    The owner's manual for the 1st Gen Prius advised that you should drive below 63 MPH during the break in period. That's an odd speed till you convert it to it's metric equivalence... 100 KPH.
    AndersOne likes this.
  6. hill
    8,913
    older or newer model, don't be deceived by your info screen showing motor not "running". The ICE still has to spin up at 'SPEED' - at some MPH point. It took older Prius owners a bit of time to determine what MPH necessitated ICE being spun up - but I'm sure someone is already working on determining the newer model's mph spin-up speeds as well. I'm looking forward to reading up on what the new Gen5 MPH parameters are for "heretical mode" as well.
    #6 hill, May 9, 2024
  7. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    That's part of it, but the other part is the changes in gear ratios. Since G3 there's been a reduction gear in-between MG2 and the planetary gearset, and that allowed the final drive ratio between the planetary gearset and the wheels to be reduced. Which means that with the ICE off, MG1 spins less fast for any given wheel speed.
    G3 actually had a lower MG1 rev limit, but still a slightly higher ICE-off speed.
    The no-ICE limit for the G5 plug-in is 84mph, same as the G4 plug-in. Don't think it's been determined for the G5 non-plug-in, but for G4 that was 74mph, so probably at least that.
  8. ChapmanF
    18,526
    Thanks for catching that; yes, my notes have final drive ratios around 3.905 for gen 1, 4.113 for gen 2, and 3.268 for gen 3.
    So even if the specs for MG1 had stayed exactly constant, if the limit was 41 MPH for gen 1, it would have been 39 for gen 2 and 49 for gen 3.
    Gen 4 by my own calculations (using the tooth counts shown at 25:02 in the Weber P610 deep dive video) comes out at 2.834, or 3.218 for the Prime (different numbers are shown over at openinverter.org, which they call "ring to pinion gear ratio" and which don't include the counter driven/drive tooth counts). My numbers would correspond to 56 MPH (50 for Prime) even if nothing about MG1 had ever changed since gen 1.
    I haven't gathered those specs for gen 5 yet.
  9. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    I agree with all your G1-G4 numbers for what I've got down as the "(planetary) ring to wheel ratio".
    And the G5 values I have are:
    3.017 for the 1.8 HEV (74/20 final drive, 53/65 counter)
    3.390 for the 2.0 HEV (77/21 final drive, 49/53 counter)
    3.606 for the 2.0 PHEV (78/20 final drive, 49/53 counter)
