48 vdc to 12 vdc step down converter
Discussion in 'Gen 2 Prius Accessories & Modifications' started by sundy58, Sep 12, 2022.
  1. sundy58
    sundy58 Junior Member
    33
    Donna, TX
    I have been looking around the forums but could not find anything about using the traction battery for 12 VDC accessories. I use this amazon.com/gp/product/B07S9KDSQ5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 on my golf cart. I wonder if there is a convenient place to pick 48 volts off the battery pack to connect to the step-down converter?
  2. ChapmanF
    15,614
    The battery is made up of 7.2 volt (nominal) modules, so you could, in theory, tap across six or seven of them, and have a nominal 43.2 or 50.4 volts, maybe up to 60 volts or so at higher states of charge. You'd have to check whether the input specs of your converter could cover such a range.
    But it would be a pretty terrible idea. The car itself is only able to charge or discharge the battery using a series current through all of the modules, so any tap you added to drain only some of them would lead to battery imbalance that the car could do nothing about.
    There is a large DC to DC step-down converter built into the car, which will produce 12 volts for you whenever the READY light is on.
  3. sundy58
    33
    Donna, TX
    Thanks for the reply. So I assume the DC to DC converter is how the accessory battery is charged?
  4. Leadfoot J. McCoalroller
    7,173
    6,720
    Pennsylvania
    2018 Prius c
    Exactly.
    Now, 5 of those amazon converters in series, with the outputs paralleled? Hmmm...
    No, I won't be trying it myself.
  5. sundy58
    33
    Donna, TX
    Ah yes, the Rube Goldberg edition. :)
  6. ChapmanF
    15,614
    You can buy Gen 2 inverter assemblies for a song. Buy one, take just the DC/DC converter out (it's in the bottom), wire it up to run your accessories when the car isn't READY and the one up front's turned off?
    It's designed to be water-cooled. But then, it's designed to source 1400 watts (it's running the whole 12 volt system of the car while in READY, not just charging a battery). If you're only planning to run, say, 100 watts of accessories from it, you might get by with adding an ordinary heat sink, and not fussing with a water supply.
  7. sundy58
    33
    Donna, TX
    So that will use the whole traction battery?
  8. ChapmanF
    15,614
    That's what it's there for. It's a 201.6 volt to 12 volt DC/DC converter.
  9. sundy58
    33
    Donna, TX
    Ouch! They are not singing my tune. The cheapest I see is $150 on eBay.
  10. sundy58
    33
    Donna, TX
    I can just add a security system battery. I like to have key off 12 VDC, it's from diving Fords my whole life. I might just put my battery jumper under the seat. I have the older version of this
    Arteck 800A Peak Portable Car Jump Starter
    The link insertion thing is not working for me right now.
  11. ChapmanF
    15,614
    But then, what would 5 of the amazon converters run you?
    Plus, you'd end up with all the rest of a Gen 2 inverter for your miscellaneous parts drawer.
  12. sundy58
    33
    Donna, TX
    I have 185K on the old girl and have not done much beyond change the fluids and mess with the HID headlights. No extra parts for me.
  13. ChapmanF
    15,614
    WIth 14 big honkin' IGBTs and the like, you could be well on the way to building your time machine, or whatever.
    Just need to find a flux capacitor.
  14. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    I would strongly recommend against grabbing 48v of your nimh string to do this, unless you like bricking your car.
  15. sundy58
    33
    Donna, TX
    1.21 Gigawatts.
  16. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Just wondering. How many kWh of energy do you need? How frequently? Wouldn’t a portable lithium battery pack be a better option and recharge it as needed, even off the Prius?
    donbright likes this.
