4th Prius, but first Plug In! Help!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by keywesthairman, Jun 10, 2018.
  1. keywesthairman
    keywesthairman New Member
    Phoenix Arizona
    Four Touring
    My first Plug In. Just bought my 2012 Advanced. Only 38 k miles! My fourth Prius is you count one C model. I have questions maybe someone can help with.
    1. My electric panel is full at my house. Neighbor mentioned using like the clothes dryer line for charging the car. Just can’t do both. Made sense to me (?)
    2. Should you think of run flat tires seeing there is no spare tire?
    3. I can’t tell if the accident avoidance is on or off. I see no lights or indicators (?)
    4. Yesterday took my first significant road trip. Twice I found the EV button had gone on. Once I might have possibly hit it but I still wonder why it went on. Hhmmm
    I appreciate any help! I’m new to this sight!
    RFM
    farmecologist and bisco like this.
    51,157
    congrats and welcome!
    1) yes, if you want to buy a 240v L2 evse. the stock runs on 120v, 12 amp max.
    2) no, they are horrible. i keep a donut on the hatch floor, some throw one behind a front seat.
    3) not sure, (i have base) check the manual?
    4) i have to make sure i don't hit it when my hand is on/near the shifter, especially when i'm in ev and don't want the engine to come on. it's a terrible location.
    5) welcome to the pip club, all the best!(y)
    m.wynn likes this.
  3. gallde
    gallde Active Member
    238
    130
    Tarrytown, NY
    I once wired a hot tub to my A/C condenser's outdoor disconnect box after installing a relay such that when the A/C was on it cut off the hot tub heater. Worked fine.
    51,157
    you can plug the stock evse into any 120v outlet as long as there isn't too much running on the circuit. otherwise, it might trip the breaker.
    m.wynn and fuzzy1 like this.
  5. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    Not sure if the terminology is the same in the US, but we'd call that a "priority switch". They're fairly common here when someone wants to install a 32A EVSE (everything's 230V) and already has multiple other high current devices (e.g. electric showers - I know they're not a thing in the US!) and runs the risk of blowing the main fuse.
    Old Bear likes this.
  6. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    If you don't mind charging at 120V, you can just plug it into any outlet like it was a lamp or a toaster or something.
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    4) EV comes on whenever you turn on the car. If you're in a location where you don't want to use up the charge be sure to turn it off as soon as you start. I like the location of the EV button because I use it a lot in a hill/mountain area. If you are going down a long hill it will only add a minimum amount of charge in HV because it acts like a plain HV vehicle keeping a specific range of charge min to max. By switching to EV you get a full charge if you have enough total downhill distance in segments hence the need to use the EV button lots of times. On a recent 500 mile trip I got 59.2 mpg with only the original power line charge. The dash indicator said 60 mpg but it always reads a little high.
    jerrymildred likes this.
  8. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    My Grandmother had a kitchen with only a single 15-amp circuit. She had a similar device to unplug the toaster before using the electric waffle iron. It was called Grandpa. :)
    CaliforniaBear likes this.
