5,000 service price
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by raintree, May 9, 2005.
  1. raintree
    raintree New Member
    22
    Richmond, VA
    My local Toyota dealer is charging $89.99 for the 5,000 mile service. Is this a reasonable price?
  2. popoff
    popoff New Member
    560
    western NC mountains
    Sounds high to me.
    Oil change is all that is necessary. Book suggests tire rotation which I think is a good idea.
    This service in the express lane at the dealers I go to is $40-$45 for my Highlander. It certainly shouldn't be more than this for a Prius
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    For the 8,000km service, it's just an oil change. I had a freebie for that one, otherwise my local Toyota dealer charges $39.95 Cdn.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    My local Toyota dealer is $24.95 for oil change and I get 10% off with AAA card.
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(paprius4030\";p=\"88210)</div>
    Similar here.
    Here is what the Toyota Service booklet suggests for the 5,000 service:
    5,000 Miles or 6 Months
    + Replace engine oil and oil filter1
    + Rotate tires
    + Visually inspect brake linings/drums and brake pads/discs
    Additional Maintenance Items for Special Operating Conditions
    Driving in desert or on dirt roads:
    + Inspect ball joints and dust covers
    + Inspect drive shaft boots
    + Inspect engine air filter
    + Inspect steering linkage and boots
    + Tighten nuts and bolts on chassis
    Driving while towing:
    If your dealer is offering to do all those things, then perhaps it's worth it. But if your just getting an oil change and a tire rotation, $90 is just too dang much.
    If you did not get a service booklet, go to this site:
    http://smg.toyotapartsandservice.com/owner...Prius&year=2004
  6. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    This may help: ask for a tire rotation and oil change. Don't let the words "5000 mile service" escape your mouth. Dealers usually have a whole host of other things they do above and beyond what the warranty requires. And it's unneccesary and costly.
  7. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
    Be VERY careful what escapes your lips at the Toyota dealer's service desk. I once asked that while doing an oil change on my Camry, they see if there is anything leaking as I thought I saw a stain on my driveway and that perhaps my brakes were fading.
    The result was new front brake pads, disks machined for a total of US$198 and the following recommendations:
    Cut rear drums for $170.
    Replace valve cover gasket $99.
    Dist O Ring $107 Oil cooler O ring $133.
    Oil pan gasket $318
    Both axle boots split open $296 per side.
    Timing belt noisy and dog bone motor mount cracked $335.
    All this was hilarious fiction until I got to the end where they charged me $42.50 for writing these jokes.
    (I did have the timing belt replaced the next time there was a coupon.) I did NONE of the rest and have driven the car 10K miles since with no problems.)
  8. jo
    jo Junior Member
    Henderson Harbor NY
    A free 5000 mile service by my local (Watertown, NY) Toyota dealer
  9. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    I hope you don't get a timing belt done, because there isn't any. It is a chain.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(DanMan32\";p=\"89754)</div>
    That's where the owners of Echo Hatchback, Echo Sedan, and Prius lucked out. Maybe the Corolla too, though not as sure.
    If Genalex was referring to her prior Camry, it most likely had a timing belt too. The timing belt and valve adjustment on my 1990 Toyota 4Runner V6 routinely set me back $700.
    The rest of the Toyota models still use timing belts. That can get real expensive, especially on their V8 Tundra.
