>5 miles commute to work
Discussion in 'Newbie Forum' started by powder brown, Apr 30, 2012.
  1. powder brown
    powder brown Junior Member
    Nevada
    <5 miles commute to work
    After lurking thru this site over the weekend I noticed that many of you are posting your daily commuting miles to/from work. Well my commuting miles is less than 5 miles. I understand the 40+ MPG is a great benefit, however, should i just be looking for a civic? Will the short commute to work be a disadvantage for me since the motor turns off after 2-3 min and it takes me 8 min to get to work?
    Just curious if the Prius will be the right vehicle for me with such a short commute? Will i be hurting the motor/batteries in the long run by only driving it for such a short time by turning it off and on for about 20 min a day?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It's upto you. In winter the car takes longer to warm up, especially if you have the heating running high too.
    In summer the Prius warms up very quickly and you'll benefit from improved mpg's even over such a short journey.
    Will it be worth the extra $$'s over the Civic for fuel savings? Probably not, but then if you're just after cheap running costs a 15 year old Ford worth $400 is probably the best bet.
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    We have a gentle 1.5 mile commute. Lifetime average is 50.3 mpg actual. But that is aided by 50-60 mpg on the freeway and up to 75 mpg in longer town drives. My guess is our ultra short trips net around 40 mpg. Best bet would be a PiP, but they are not available here yet. Our worst winter tanks are 40 mpg (snow, defrost, heater, fewer longer trips).
  4. powder brown
    Nevada
    Well the summer in Vegas Is starting to heat up so I doubt the car will need to be warmed up at all. So that's a good thing.
    I also may not be saving money on fuel but I think parts and maintenance in the long run I would assume the civic would be cheaper and a lot more people can fix a civic than a Prius.
  5. ksstathead
    1,244
    245
    Kansas
    Prius maintenance cost is very low. Essentially no brake maintenance cost on Prius.
  6. powder brown
    Nevada
    Now that's good to know!!
  7. fuzzy1
    10,335
    That would be "< 5 miles".
    Unless the local temperatures are above about 170F, the engine will still need some warmup. And even above that, the catalytic converter will still need some warmup. But this is also true of non-hybrids.
    The Prius will definitely save fuel over a Civic, over any commute distance, short or long. But if your driving is only a few thousand miles per year, the saved fuel just won't add up to enough dollars to ever pay for the more expensive car.
    So, how many total miles do you drive in a typical year?
  8. powder brown
    Nevada
    Thanks i fixed it in the title but i guess i can't fix it on the heading.
    I was being facetious about warming up the engine.
    I have a few other cars for different occasions. But for my daily driver to/from work i would say less than 10k.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    If you drive less than 10,000 miles a year then just about any 30+mpg car will do. Choose a car that best suits your needs and desires. An electric would be a sweet option for such little driving.
  10. bisco
    51,141
    ^ listen to the man, he knows whereof he speaks. ^
