5 second 0-60 for the Leaf!?
Discussion in 'Nissan/Infiniti Hybrids and EVs' started by efusco, May 8, 2010.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    This is the first legitimate news agency I've heard report a 0-60 time, but during tonights CBS evening news they ran a story on the Nissan Leaf and EVs and quoted a 5 second 0-60 time for the Leaf. The story is still not posted on the site, but I would expect it will be soon.
    CBS Evening News with Katie Couric - Latest News & Videos - CBS News
  2. atroader
    atroader Engineer
    39
    Atlanta, GA
    A comment: ~200 ft-lbs for ~2800 lbs would require rather perfect CVT gearing (holding peak power during the accel run), and I still think this would just be too much car to move this quickly with only a 80 kW motor. Correct me if my #s are wrong.
    Additionally, the wheel and tire package on the leaf doesnt look like it could provide the traction for a 5 second run w/o spinning, so there could be a problem getting the torque to the ground anyway.
    Having a nissan and a prius, I am a fan here, but I call bogus. Maybe 7 seconds. It's not a Tesla.
  3. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    atroader: there's no need for a gearbox on an EV. The purpose of the gearbox on a regular car is to multiply up the torque, because a spark engine produces its maximum torque with a fully-open throttle which is generally only possible at moderately high revs. The electric motor produces maximum torque at switch-on and is only really limited by how much power it can handle.
    The spec sheet gives the Leaf's motor a maximum torque figure of 280Nm (206.5 lb.ft), but this may well be multiplied up by fixed gear ratios before getting to the road.
    The early Tesla Roadsters have a gearbox but it's stuck in first gear. Newer ones only have a single ratio.
    The tyres clearly must stick far better than you might think, because stopping times are usually way faster than accelerations. (OK, for stopping, drag helps you while you must overcome drag when accelerating, but even so, the tyres have to cope with the force going through them.)
  4. efusco
    19,891
    1,192
    Nixa, MO
    I'm pretty skeptical of the 0-60 numbers, not sure where they came from.
  5. Tideland Prius
    16,154
    5 seconds seems a little wasteful in a small commuter vehicle (Would Nissan allow that quick of a discharge?) I'm thinking 7-8 seconds is probably more likely.
  6. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    With the HP of 110 and the weight at 2800lbs a normal ICE car would do 9-11 seconds. Even with 100% torque at zero I would not imagine better then 8 seconds, and that would be pretty good.
    A V6 Mustang 2005-2009 is 6.9 seconds. My 2004 is 8.6 seconds. Could my new Leaf be FASTER then my current Mustang?
  7. Prowler
    Prowler Newbie
    38
    TEXAS
    That would be nice, then I could beat my wifes SRT-8 Challenger to at least 60.
  8. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
  9. srossnz
    srossnz Junior Member
    New Zealand
    These speeds are possible in small EVs but not sure if the leaf will be in that category. The entire sports car industry will be shaken up in about 5yrs when guys are running little EVs like a leaf and doing 0-60 in 2.5 seconds. You'll have guys in $30,000 EVs beating a Bugati Veyron.. Top Gear will not be amused hehe..
  10. divango
    divango New Member
    16
    Tennessee
    I
    You are exactly right! No one ever thought they would see Honda Civics pushing 500 HP to the front Wheels.. We are going to see some cool and exciting mods when the Fast and Furious crowd take time from playing Xbox to break out the laptops and go to work on the EV Rockets! Can't wait to see Jeremy and the boys at TG Smoking the front tires around Hammerhead...
    Nissan Leaf Forum and Owners Group
  11. hill
    8,180
    Well, Automobile.com sure isn't coroborating the "sub-6 seconds" time:
    2011 Nissan Leaf Preview
    It aint the 1st dope that CBS has smoked. After all, the TESLA does 5.6 seconds from 0-60.
  12. hampdenwireless
    1,104
    86
    Baltimore MD
    Maybe that is how they came up with that number, they used the Tesla number accidentally.
  13. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    i'd say 10.5 seconds or so. sure, 0-20 will be fast, 20-40 will be acceptable, but 40-60 will take a while. and 60-100? slow. the volt/ampera has 112k, and that's been quoted as "sub ten seconds".
  14. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
  15. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i think they misquoted... its 0 to 60 KILOMETERS per hour in 5 secs.
    after all, the only real ones (besides the ultra secret ones in the US) are in Japan. they run metric there. besides at the Leaf Tour, it was said that it would accelerate "like a typical 6 cylinder".
  16. Tideland Prius
    16,154
    So 8 seconds then... just like the EV1
  17. leaffan
    leaffan New Member
    25
    AZ
    2.5l v6 :)
  18. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
