50 ft extension cord - 14 gauge - Is it safe to use?
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Sep 20, 2017.
  1. Sid786
    Sid786 Active Member
    262
    146
    Cherry Hill, NJ
    Is it safe to use a 50ft extension cable with 14 gauge for connecting to charge Prius Prime and connecting to charging cable to charge at home with 110v?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,638
    Farmington Hills, Michigan
    dono, will it handle at least 15 amps continuous current? if so then yes. that's 1650 watts
  3. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,301
    3,517
    Anaheim, CA
    I've used a 25 ft 12 Gauge for over 6 years (mostly with 2012 PIP), and it works fine. The TOTAL length is 50 ft;
    I wouldn't go longer.
    priuscatprimeguy likes this.
  4. Washingtonian
    Washingtonian Senior Member
    710
    608
    You would be safer with a 12 gauge extension cord. I wouldn't recommend using a 50 foot 14 gauge cord for charging your Prius.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,017
    Westminster, Colorado
    It's safe, under some conditions.
    Basically the problem is heat.
    If the wire is kept stretched out and in a reasonably cool environment, it's probably safe. It should be noted that the EVSE the car came with uses a 14 gauge cable. I've been using it coiled and it's been fine, but it's 105°C rated cable, while many extension cords are 85°C or even 75°C rated. Because of that difference, I generally recommend 12 gauge if you're going to use an extension cord, especially if it's going to be either in the sun or in a hot environment like an uninsulated garage in the summer sun.
  6. What if you dropped the current to 8 amps? There is a setting in Charge Settings instead of maximum current you can use 8 Amps, so 110 V x 8 A = 880 Watts. This would also mean 10 hours of charging I would think, but so what, you're charging it overnight anyway, right?
    arthur92710 and Oniki like this.
  7. bisco
    48,862
    if you do go with it, check the plugs at both ends frequently, they tend to heat up faster the the cable itself.
  8. priuscatprimeguy
    2,730
    2,638
    yup, that would work:D
  9. PT Guy
    PT Guy Senior Member
    1,074
    707
    Washington, the state
    Very important point. Start with the receptacle. If it has a lot of years or a lot of use, replace it. Buy the $2.59 receptacle, not the 59¢ one. You want good, tight contacts inside the receptacle with both the wires and the plug blades. Be sure the plug blades are clean and in good condition, not bent. Do touch all the parts occasionally. If you feel warmth, upgrade the parts.
  10. priuscatprimeguy
    2,730
    2,638
    here's a 12 Gauge 50 foot
    Sid786 likes this.
  11. David Beale
    David Beale Senior Member
    5,963
    1,979
    Edmonton Alberta
    I build my own and they last. I use #12 and #10 gauge "cabtire" cable. They are very expensive. The one I made to power the garage before I installed buried cable cost me $150. But it doesn't heat up, even when block heaters are plugged into it. The old type "immersion" heaters, that actually heat the block, that draw more than 900 W. The one in my old Subaru was 1700W. The heater blew warm air as soon as the car was started!
    Do consider the outlet you are plugging into uses 14 gauge wire from the breaker box and could be 50 feet long. As stated above, as long as it's not left coiled up the heat shouldn't cause any problems, though that from someone living where 30C is "hot". ;)
    HPrimeAdvanced and jerrymildred like this.
  12. Sid786
    262
    146
    Cherry Hill, NJ
    Thank you all for the response.
    Yes, I am only looking for overnight charging and if there is a setting, as you mentioned, to drop the amps to 8A, then I can drop it to 8A and let it charge safely, even if it takes longer.
    I am in an apartment building and I can use the Air Conditioner plug, which I am assuming will handle this charge. I am estimating that a 50 ft cable will do the job. During the winter time, there is no use of AC, so this plug will be available for charging.
    A/C rating is 10000 BTU and it says 9.8 amps with 115 V, so hopefully reducing my charging to 8 amps should be fine.
    I just want to avoid any short-circuit, damage to the car or even fire hazard.
    Maybe I will test this for few hours only at first.
  13. Lee Jay
    5,850
    4,017
    For reference, a hair dryer draws about 15A, a vacuum cleaner draws about 12A and a big garbage disposal draws about 8A. The difference here is the length of time - hours instead of minutes.
    I've been charging my Prime off a 15A circuit with a 35 foot 12awg extension cord tied to the loosely coiled up EVSE. The thing that gets the warmest is the EVSE cord near the velcro band tying it together and that's only about 15°C above ambient.
  14. Since2002
    Since2002 Senior Lurker
    936
    1,097
    Duluth, GA
    You could check the temperature by feel which might be good enough but I would think using an infrared thermometer would be even better, especially to detect if the temperature of the cable is rising which would be hard to do by feel. I would think an inexpensive thermometer would be accurate enough.
  15. bps
    bps Active Member
    304
    119
    Thanks! I just ordered one. It looks like a handy tool to have.
  16. Oniki
    Oniki Active Member
    652
    499
    Colorado
    Any chance of someone tripping on the cord ?
    HPrimeAdvanced likes this.
  17. David Beale
    5,963
    1,979
    Edmonton Alberta
    The circuit you intend to use is a 15 Amp one. They usually dedicate a breaker for the air conditioner, as they tend to operate near max current when starting up. You should be able to charge at the higher rate. Do note, if there is voltage drop in the extension cord the current may go up to compensate. I would purchase a 12 gauge cord.
    Oh, and yes, the tripping hazard would be greater than the electrical hazard. ;)
    arthur92710 and HPrimeAdvanced like this.
  18. William Redoubt
    William Redoubt Senior Member
    1,215
    1,164
    Coronado Island, California
    At 50 feet you should be using a No. 12 wire size. Don't cheap out on this. Too light of gauge is a fire hazard. I would use an outdoor cord, and build it myself with the proper HD ends.
    HPrimeAdvanced and Mark57 like this.
  19. Sid786
    262
    146
    Cherry Hill, NJ
    Is there a way to test the amps capacity of a circuit. For example,can I use a multimeter and plug it into my Air Conditioner plug to tell me the max amps I can draw from this circuit.
  20. GregoryG
    GregoryG Junior Member
    Forest Grove, OR
    As previously touched on, a thicker cord will reduce electrical resistance and therefore heat. It takes energy to produce that heat, which means that a thicker cord will save you a bit of energy.
    For example, the American_wire_gauge Wikipedia article gives the resistance in milli-ohms per foot for various wire gauges.
    • 14 gauge: Resistance = 2.252mOhm/foot * 50 feet = .113 ohms. Voltage drop = (.113ohms*15A) = 1.69V Power used = (1.69V*15A) = 25.3 watts
    • 12 gauge: Resistance = 1.588mOhm/foot * 50 feet = .079 ohms. Voltage drop = (.079ohms*15A) = 1.19V. Power used = (1.19V*15A) = 17.9 watts
    So, you can save about 7 watts during charging by using the thicker cord.
