50% Vinegar Mixture to remove hard water spots
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cary1952, Aug 8, 2013.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    My last car wash left terribly ugly hard water spots on my car (nautical blue) . I tried waxing the hood but they were still showing. I read online about using 50% vinegar mixture. Holy Batman! That method worked well! Have to rewax the car today however as the vinegar supposedly removes the old wax.
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    I use a spray bottle and a damp cotton cloth. Works like a champ!
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I wouldn't recommend using vinegar. It's acetic acid and -could- damage the paint. I've found just using water will remove the spots, then dry with a microfibre towel before it air dries. Some car soaps will stop water spotting as well. Cleaning with it should also remove the spots. Car soap is made so the pH (acidity/baseity - if that could be a word) is compatible with paints.
  4. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Using water did not remove the spots for me.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    An acid bath consisting of distilled white vinegar is actually what pros use if they're certain that the water spots are mineral deposits. However, it's best to use the least aggressive product to get the job done. Claying or a polish with mild abrasive (or even chemicals like Nufinish) can usually remove water spots.
  6. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The word would be alkalinity. ;)
    SCH-I535
