50MPG from Chevy Cruze Diesel
Discussion in 'Diesels' started by Troy Heagy, Feb 6, 2017.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    I'm buying this car. It's called the Whisperdiesel in Europe:
    "The first nonhybrid car since the 80s to get an EPA highway rating of 50 mpg or more." The previous record-holder was 51 mpg for the 1987 Honda CRZ HF (which would fail to meet current emission standards).
    "The Cruze with the six-speed manual will get higher fuel economy than the model with the nine-speed automatic..... to keep diesel chatter low, the fuel injectors shoot as many as 10 squirts of fuel per stroke."
    LINK: http://www.autonews.com/article/20161011/OEM04/161019959/chevy-cruze-diesel-hatchback-may-claim-highway-mpg-crown
    #1 Troy Heagy, Feb 6, 2017
    pleasedpriusowner likes this.
  2. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Samprocat likes this.
  3. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    You have not considered regenerative system that will kick when your system determined ....and it will drop your efficiency down to gas engines.....
    If you are in Europe consider VW 4 cyl diesel or BMW 4 cyl diesel..you will get besr efficiency with BMW 4 cyl Diesel....
    Don't let media's make you believe something that is just not true.....
    And Cruze diesel is 1.5 generation behind in common rail injection..with similar year like VW or BMW....
    And they are not definitely low on noise....
    I have buddy with this type of engine and there is nowhere close to statement of quietness or that type of efficiency....
    There is way to make this engine to run that type of efficiency......and that will be removing entire emission system and tuned to accommodate free flow and no backpressure....
    #3 Samprocat, Feb 7, 2017
  4. Troy Heagy
    Troy Heagy Member
    1,218
    I'm not the one doing the testing. The EPA regulations take into account the effect of the regeneration system, by directly measuring the amount of fuel consumed on the City & Highway test runs. So if Chevrolet (GM) estimates they will get 50 MPG highway, that's what they are seeing in actual, official EPA tests.
  5. Samprocat
    491
    297
    Lincoln, NE
    If you own one.....you will be disappointed.....that this what they advertising are very hard to make....
    Believe when I say.....i have rented this car in USA and Europe.....for 2+ months each place.....and try my best to see this numbers everyone is saying with normal drive.....
  6. Rmay635703
    Rmay635703 Senior Member
    2,690
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    City is much lower but with an 5 MT and mild hypermiling you can beat EPA city.
    My old gas cobalt XFE was 50mpg all summer just hypermiler and drive slow
  7. Samprocat
    491
    297
    Lincoln, NE
    Definitely remember that type of the car. I was in Albuquerque...and i have rented then when they just come out...and they did amazing MPG....
  8. bisco
    52,819
    can't stand diesels. they represent everything that's wrong with the world. like coal rollers. might as well have coal fired cars.
    raspy and Prius Pete like this.
  9. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    I used to have a manual transmission 1992 Honda Civic VX. Loved that car! It was rated at 51 MPG...and I was actually able to get that on the highway. In fact, it was the reason I was skeptical of Hybrids for so long ( but have since 'seen the light' ). In fact, my daughter still remembers the car..she used to call it 'little red' when she was very young.
  10. Samprocat
    491
    297
    Lincoln, NE
    No way....Today new diesel smell like rotten eggs....and require another fluid Urea......They run clean and smooth....just the way this emission is designed...it will burn more fuel and all improvements in driving will get lost each time Cat....need to Regen
    They have purpose ..just not for users of short trips....
    And yes ....there is much better technology to be used instead Diesel
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    37 MPG combined for the manual and 31 MPG combined for the automatic is so bad, it's not possible to take it seriously. No mention whatsoever of emission-rating is the evidence of being severely wounded, especially from all the awareness raised by the cheating scandal. After 15 years of tolerating the claims of being as clean & efficient, it's time to move on. Gen-4 Prius easily surpasses that it both regards. Adding a plug to it to make a Prime buries the coffin. Diesel for passenger cars is dead.
    Prius Pete and telmo744 like this.
  12. bisco
    52,819
    diesel also costs more, if you want to through that into the equation.
    thatoneraccoon likes this.
  13. bwilson4web
    16,525
    Like EV skeptics claim about midwest EVs?
  14. bisco
    52,819
    not familiar, what's their claim?
  15. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I was just thinking, what would happen if the cruse diesel had a hybrid setup like the prius, I wonder how much better the mpg's would be then o_O
  16. bwilson4web
    16,525
  17. thatoneraccoon
    201
    146
    Ohio
    yeah, ive heard such, a majority of our electric comes from coal fired power. So I guess that would make my Prime a rolling coal boat
  18. bisco
    52,819
    there's an easy fix, more wind and solar. maybe those skeptics would like to push for a change.:cool:
    bwilson4web and thatoneraccoon like this.
  19. thatoneraccoon
    201
    146
    Ohio
    id like some solar panels on my house :D
  20. bwilson4web
    16,525
    Someone suggested:
    The problem is dirty coal which like "clean coal" has as much credibility as the VW "clean diesels" After all, house power comes from the same dirty coal power plants.
    Being a rascal from time to time:
    You are right about EVs using coal fired electricity so let's go burn down someone's house and free up enough electricity to power 3 or 4 EVs. You bring the gasoline.
    bisco and thatoneraccoon like this.
