52,000 miles how important is it to drain & refill hybrid coolant, flush regular cooling system, is
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Claire2015Prius, Feb 13, 2020.
  1. Claire2015Prius
    Claire2015Prius New Member
    Orlando
    Car is 2015. Don’t drive much. Just had dealer change oil & they have me a list of things I should do for a whopping $914.69.At 52,000 miles how important is it to drain & refill hybrid coolant, flush regular cooling system, service FIS fuel induction system, FIC fuel injectors cleaning, ACI evaporator core cleaning,brake fluid replace? My car did make a smell after a long drive last night? Also after the oil change the maintenance light came on? Maybe they just didn’t reset it?
    51,972
    None of those are necessary.
    Check your maintenance schedule and follow it, using either months miles
    The o/m shows how to reset the maintenance minder, and the smell is because they spilled oil all over your engine
    dig4dirt likes this.
  3. fuzzy1
    10,469
    All this comes from their need to make their next vacation home payment, not from your car's maintenance schedule.
    You might want some early fluid replacements, but those should come when you deliberately want such and go ask for it, not from any service writer's up-sell attempts.
    Yup, after all that hard sell, they forget the essential element of resetting the maintenance reminder. The simple procedure is in your Owner's Manual, and in multiple threads here.
    Extreme, dig4dirt and jerrymildred like this.
  4. Mendel Leisk
    41,486
    Talk to the service manager. Tell them you'd like to follow the required maintenance schedule, don't want the upsells. See how he/she reacts. If you sense a smoke screen, talk to other dealerships, again the service managers: hopefully some of them are more on the level.
    US schedule, converted to graph format, per the Toyota USA warranty and maintenance booklet (you can download pdf of this booklet from Toyota Tech Info):
    Note: the inverter coolant in particular, according to Toyota USA, is not due for replacement until 150K miles or 15 years, whichever comes first.
    Would you want to share the name of the dealership?
    Cactus Chuck, dig4dirt and fuzzy1 like this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Damn, after all that try of robbing and stealing, they try put money on double or nothing.
    Posters above added what you should do.
    Follow maintenance schedule.
