52 mpg in the morning, 58 in the afternoon
Discussion in 'Gen 2 Prius Fuel Economy' started by pardreamer, Feb 8, 2008.
  1. pardreamer
    pardreamer Member
    114
    San Diego
    I leave my house at 5am when temperature is around 43F and go home at around 3:45pm when temperature is around 70F. I wonder if the difference in temperature caused the different in mpg or maybe it is the difference in elevation.
    My commute is from San Diego, CA to Anaheim, CA. Not sure which one has higher elevation though.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    That temperature difference is likely more than enough to account for the difference. Good results on either leg, regardless -- well above the new EPA numbers. Congrats!
  3. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    I agree. Great mpg numbers in the warmer parts of the US. Two days ago, we had a warm spell and my mpg jumped up to 49 ;). I still have three pips on the fuel gauge until my next fill up. Hopefully this tank will be my best in terms of mpg.
  4. Aces
    Aces Member
    66
    Seattle
    I'm out in Seattle, where the temperatures are pretty mild. But the hills take a beating on my mileage. I recently found a route that has slower speeds and more gradual hills, and it improved my mileage. I too notice a consistent difference between my morning & evening commutes. But the morning one is better. It's something like 56 vs 52 mpg. What I think is causing the difference is the way the hills are set. The morning route has long stretches of gradual downhills. So on the return trips I end-up with long stretches that tend to turn the ICE on. The route is mostly 40 mph, but with a fair amount of traffic lights.
    So I guess I'm saying it could be terrain related too.
  5. PRIUS007
    PRIUS007 James Bond -007
    133
    Mundelein, Illinois
    Here in the Chicago area it's been COLD. This morning when I left it was -2F and I got 38.4MPG on the way in. This afternoon it 'warmed' up to 14F and I got 53MPG.
    The other week when it was in the low to mid 30's, I was seeing 56.1MPG.
  6. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    WHAT??? fifty-something?? Man, its winter time and I'm getting 45.6 and I have to be happy about it!! :D (forced smile)
  7. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    I've carefully monitored and documented the temperature effect on mileage:
  8. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    Very nice work!
    Rob
  9. richard schumacher
    7,664
    1,043
    United States
    The higher outdoor temp helps in two ways:
    1. it lets the engine reach optimal operating temperature sooner
    2. it increases tire pressure, and harder tires have less rolling resistance
  10. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    Outstanding MPG! I know the route quite well. Do you take the 5 freeway? What is your average speed? Do you use cruise control? In short, tell us your technique. :) I'm impressed.
