5w-30 oil ruining my engine?....
Discussion in 'Prius v Main Forum' started by Georgie girl, Mar 7, 2022.
  1. Georgie girl
    Georgie girl New Member
    San Diego
    2014 Prius v wagon
    So I accidentally had the mechanic put in 5W-30 oil instead of the 0w-20. Now the engine shits off and the hybrid battery was run low trying to run the engine with this thicker oil. Oil was drained, refilled with right oil, and filter changed again after driving just a couple hundred feet in parking lot at the auto shop. It’s getting towed to the dealership. Is it permanently damaged and hopeless or can Toyota technicians fix it? It’s a 2014 Prius v
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,977
    4,718
    Texas Hill Country
    The oil had nothing to do with the hybrid battery issues you may or may not have. If the mileage is over 150k miles the battery is possibly weak.
    There are several other hybrid related issues with this model including the brake booster or inverter. The inverter is one item that would be covered by Toyota even with high miles.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    The different oil had nothing to do with anything.
    There actually isn't THAT much difference.
    0W20 actually might not be the best choice in a HOT environment.
  4. Mendel Leisk
    38,728
    Yeah let your poor mechanic off the hook. Slightly thicker oil was not the culprit.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    Overfilling would really cause damage.
  6. bisco
    49,500
    can you give us more details on performance?
    how many miles on your car?
    did you get any warning lights?
    yes, the toyota techs can fix it
  7. sam spade 2
    7,035
    2,788
    2017 Prius c
    The key word is missing: CAN
    Actual overfilling CAN cause damage.
    But your typical "half an inch" or less above the full mark doesn't really qualify.
  8. rjparker
    7,977
    4,718
    Texas Hill Country
    It could have been empty for that long without serious damage. The difference between the oil used versus spec is insignificant.
  9. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    That is a Very Naughty Mechanic...... he should be made to drive a honda insight......
    Is this a fake post?
  10. rjparker
    7,977
    4,718
    Texas Hill Country
    Good deal. I would suggest finding an independent hybrid shop in the Socal area you can use for oil changes and other maintenance work as it comes up. You may hear from a group of old guys here that diy is the way to go. I don't subscribe to that as a general rule especially without some level of experience. But establishing a relationship with an independent shop will save you money on most regular maintenance items and is more likely to give you a balanced opinion on some optional items you are sure to hear about.
  11. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Get rid of it before all of the really bad stuff starts happening
  12. bisco
    49,500
  13. bisco
    49,500
    interesting that the quote in post #10 is missing (n)
  14. rjparker
    7,977
    4,718
    Texas Hill Country
    Info from PM.
  15. bisco
    49,500
    ah, thank you
