6-8 mpg boost for a high mileage Prius
Discussion in 'Gen 3 Prius Fuel Economy' started by Travisfixingaprius, Jul 22, 2022.
  1. Travisfixingaprius
    Travisfixingaprius Junior Member
    31
    US
    If you have a higher mileage Prius consider replacing spark plugs and ignition coils.
    replacing both brought my MPG up by 6-8mpg.
    my average went down to 35mpg and it’s now consistently 40-42. My car has 149,000 miles on it.
    ColoradoBoo and mikey_t like this.
  2. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Mine has almost 200,000 miles and I yield 65 mpg per tank for the last 3 years. Are you sure I can get 71 mpg if new plugs and coils are swapped in?
  3. PriusHead05
    PriusHead05 Member
    304
    87
    Mine has 208k mi. and I get an average of 52 mpg. The highest I have gotten is 65 mpg. That was in the winter. Now here in Florida, running the AC constantly hurts mpgs. I can get 60 mpg if I have my fan speed on the lowest setting. @Grit how are you getting an average of 65? Any special. I've tried driving techniques and increasing my tires +2 psi. Anything else you'd suggest to get better mpgs?
    49,488
    try getting rid of excess weight
  5. PriusHead05
    PriusHead05 Member
    304
    87
    I did. There's nothing in the trunk.
  6. bisco
    49,488
    spare tire? rear and passenger seat? tool kit and jack?
    you have to think outside the box like @Grit
  7. PriusHead05
    PriusHead05 Member
    304
    87
    I could remove myself out of the car...
    Priipriii, chuckiechan and bisco like this.
  8. bisco
    49,488
    i lost 50 lbs, but i needed to :cool:
    PriusHead05 likes this.
  9. PriusHead05
    PriusHead05 Member
    304
    87
    Do the 17in. rims help with mpgs or no? I've heard they are lighter than the steel, but they are also wider and creat more drag. I currently have the 15in. steelies.
  10. bisco
    49,488
    it's the centrifugal force that causes larger wheels to lower the mpg's, even when lighter
  11. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    How are you driving? If you drive 70mph+, you're mpg will drop.
    Those who are getting 55mpg or more are usually doing under 60mph.
    And are driving very Priusly.
    CR94 and PriusHead05 like this.
  12. J.T.
    J.T. Junior Member
    Virginia
    @PriusHead05 Did this as a part of "preventive maintenance" at 120k miles and had the complete opposite effect. My mpg dropped 8-10mpg, from 52-56 down to 45-48. If you are getting good mpg (better than factory ratings) already, do not do a thing. Ride it until you have a substantial decrease and then consider changing plugs.
  13. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    Your wheels aren't steel; the only Prius that came with steel wheels was the C.
    OEM 17" are several pounds heavier than 15".
  14. ChapmanF
    15,614
    How many miles were in the numerator of the 35mpg, and how many now in the numerator of the 40-42?
    The car's ECM computes a fairly sensitive measure called the "misfire margin", which you can read with a scan tool. This number can be negative (misfires are happening) or positive (if less than 30, at risk for misfiring; higher than 30, not really at risk, higher is better). Last time I checked mine it was something like 134. At that rate, I doubt there would be much improvement possible for me at this point. (I'm at 157,xxx, but not on the original plugs).
    If your current misfire margin is lower, getting down near 30 or worse, then it is possible a change of plugs could improve something. It could also be worth investigating whether anything else is going on with the engine that could be contributing to the low margin.
    Jotting down the number before and after the plug change could be another nice way of quantifying the effect of the change.
    CR94 likes this.
  15. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    If your car is in good shape, just the basics including
    1) Avoid short trips;
    2) Avoid high speeds;
    3) Avoid unnecessary braking (including regenerative);
    4) Coast with engine off when safe and practical;
    5) With AC, use highest thermostat setting you're willing to tolerate. The 2nd-lowest fan speed is ok.
    6) Use recirculate setting with AC (whether manually or by selecting ECO mode button).
    People getting significantly higher mpg than you are doing most of the above, most of the time. Unfortunately, most people don't have the patience.
  16. Mendel Leisk
    38,726
    God no, and we’ve got them. They weigh around 24 pounds apiece, and with larger OD centrifugal force is more as well. And they’re 20 mm wider.
    How did the old ones look?
  17. Travisfixingaprius
    31
    US
    Well I’m no where near that at 150k miles.
    Damn maybe I have more issues wrong with my car than I thought! Lol
    Limey Geoff likes this.
  18. Travisfixingaprius
    31
    US
    I drive for Lyft and do mix of city freeway driving when I use my car for package delivery.
    even before doing Lyft and my new job I still never reached above a 42mpg if I was lucky.
    Right now averaging back at 38.5 mpg for the last 2 tanks
    ASRDogman likes this.
  19. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Huh? How are you thinking that relates to fuel consumption?
    a = v²/r
  20. PriusHead05
    PriusHead05 Member
    304
    87
    The ECU is not used to the new plugs. If you want to speed up the relearning process, just disconnect the 12volt battery for a few minutes and then reconnect it.
