60 MPG in an Accord Non-hybrid (Wayne Gerdes)
Discussion in 'Other Cars' started by Troy Heagy, Jan 21, 2014.
  1. Troy Heagy
    Troy Heagy Member
    1,218
  2. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    To my knowledge, his ignition and starter motor are original.
  3. Trollbait
    12,351
    He mentioned having to replace the starter in a post once in passing.
  4. Troy Heagy
    Troy Heagy Member
    1,218
    I wonder what he could do with a VCM Accord that can switch from 6 to 3 cylinder mode? Wayne might go as high as 80mpg.
  5. fuzzy1
    10,335
    Why bother when he can get double that out of a Prius?
  6. Trollbait
    12,351
    Unless there was a way to hack it so you could go 3 cylinder on demand, he would get worse. For accelerations, where most gas is burned, the engine will be pumping all six cylinders, and for the times when the VCM kicks in for mpst of us, he'll have the engine turned off.
