60k dealer service
Discussion in 'Gen 2 Prius Main Forum' started by flyboy09, Mar 20, 2008.
  1. flyboy09
    flyboy09 Junior Member
    Seymour Tennessee
    would $570.00 be a fair price for 60k service on a 2005 prius?... my wife thinks this is too much to pay the dealer. just wondering also if something mysteriously will cause a more expensive repair in the future if the 60k is not done???:confused:
  2. svbb
    svbb New Member
    27
    I just paid $350 for my 30,000 mile service. You might call another dealer and see what their price is for the service. The first question: Is this service the Toyota Scheduled Maintenance, or is it the "Dealer Recommended?"
    My dealer adds all kinds of additives (BG products, synthetic motor oil, etc), that add about $50 to the price of a regular oil change.
    I know that lots of people will disagree with me, but my opinion is that I will have the longest life from my car by following the Manufacturer Recommended Maintenance Schedule and by having the maintenance performed at the dealer.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Are you handy? Me @ 60K would change out the transaxle fluid for sure. Just did it myself and its pretty easy. Takes 3.8 quarts of Toy WS. Open up the rad cap not overflow and look at the coolant. Is it clear & bright red? If not let the dealer do that change. Change the air & cabin filter. And again if me I would pull the plugs, clean them check gap and put anti-seize on them.Letting plugs sit in a head for 100K before breaking them out is just nutty. Maybe a tire rotate but thats about it I bet.Brakes go crazy long on our car before re-pad unless your having brake problems. Good luck.
  4. flyboy09
    Seymour Tennessee
    just found the maintenance log 2005 pruis....looks like engine oil and filter, rotate tires, cabin air filter, engine air filter, ....inspect the following..atf fluit ball joints and dust covers brake lines hoses etc for brakes, diff oil drive belts shaft boots engine and inverter coolant engine valve clearance exaust pipes fuel lines etc fuel tank cap gasket radiator condenser and intercooler steering box and linkage...:confused:
  5. richard schumacher
    7,663
    1,038
    United States
    $570 is pretty pricey. *Don't* ask a dealer for "their X miles service". They'll charge you for a buncha stuff that the Prius does not need, or indeed cannot even be performed on a Prius. Instead take the scheduled maintenance guide that came with your Prius and show the X miles page to the service writer. Tell them to perform those items only, no more and no less, and see what that will cost. For X=60,000 I'd bet you could get it for $300 or so.
  6. hill
    8,152
    Wow! Some of your are way over spending, AND over doing maintenance, according to a certified prius tech, that did a nice write up on necessary maintenance, under the maintenance threads. Read up, and save, folks.
