Car Talk Prius Question Not Really Answered
Discussion in 'Gen 2 Prius Technical Discussion' started by TonyPSchaefer, May 17, 2009.
  1. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Yesterday morning I was listening to Car Talk and a woman called in from Connecticut. She reported that during long-distance drives, she would pull over to take a cat nap. After about a half hour, her 2007 wouldn't start.
    It sounded to me like a typical 12v problem, perhaps a bad battery, a faulty connection, or the like. But I'm thinking that if the problem really was with the battery, the distance of the driving shouldn't matter. For example, she didn't say, "every morning I have to have my car jump started." She only said that it was during long trips.
    I am going to try and post the MP3 of the segment. I downloaded the podcast and snipped that segment. Since MP3s are not uploadable, I renamed the file to *.zip. Just change the extension back to MP3 and it should work. If not then I'll post it on a server.
    And I'm also planning on trying to notify the owner that I've started a thread to discuss her problem. I know Click and Clack did the best they could but I know that the collective knowledge here could probably do a lot better.
  2. Dobey
    Dobey New Member
    It would be really good if she also outlined what else she does while cat-napping, e.g if she leaves something on in the car powered by the 12V battery... I know of one work person who goes out to her car at lunchtimes and reads a book with the fan on full blast and the motor off...
  3. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Or perhaps she leaves something like a laptop ect. plugged into one of the outlets
  4. Patrick Wong
    18,210
    6,513
    Yes, suppose this woman leaves the car IG-ON (not READY, where the various instrument panel warning lights are on) and has the ventilation fan running, the stereo on, etc. If the 12V battery is in marginal condition then the battery would be sufficiently drained after 30 minutes so that the car would not start.
  5. TonyPSchaefer
    14,816
    2,501
    66
    Keep in mind that she says that she pulls the key out of the ignition.
    This rules out leaving the car IG-ON. The only thing potentially providing power would be the single outlet on the passenger side. Is that one always-on?
  6. richard schumacher
    7,666
    1,047
    United States
    She may have SKS and not know it, in which case pulling the fob out of the slot would have no effect, true?
    As Tom and Ray noted, on those occasions when her Prius won't start Elsie has undoubtedly not shut it off; she has left it in ACCessory or IGnition-ON. The Prius 12V battery is a wimpy little thing, and having been drained a couple of times it's now toast and needs to be replaced. After doing that the simple solution to Elsie's problem is to *leave the car completely ON and Ready* during her catnaps. She should shift into Park, set the parking brake, and lock the doors. She can then sleep as long as likes even with the A/C and the radio on with no harm done until she runs out of gas. Starting with a full tank of gas it would take about an entire day to run out under those conditions. It is extremely important to shift into Park and not Neutral, both for safety and because the car cannot recharge its batteries when in Neutral. And of course this should only be done in a well-ventilated area or outdoors, and not in a completely enclosed space.
  7. TonyPSchaefer
    14,816
    2,501
    66
    I think someone posted somewhere else approximately how long it would take to drain a 10-gallon refill if the Prius were left on. I know that some people leave their Prii on during car shows. The shows last all day, the engine kicks on and shuts off as needed and they use relatively little fuel.
    That's a great idea moving forward. But have we pinpointed what caused the problem in the first place?
  8. daniel
    14,487
    1,519
    Spokane, WA
    I have not listened to the segment. I'm going by what's posted above:
    If she has her headlights on while driving, then shuts the car off, but does not turn off the headlights or open the driver-side door, BINGO: dead 12-v battery.
  9. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    10 gallons takes roughly 4 to 5 days...
    good observation daniel
  10. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    I, too, have not listened to the show, but I think Daniel's come up with a very likely cause of the problem.
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Good thought Daniel, that would sure do it. Since the door never opened, the lights never shut off.
  12. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    This begs the questions: How long would it take for the headlights to drain the 12v battery, and how long a nap did she take?
    Of course, battery health and SOC are big factors, but I would hope the 12v battery could handle the the headlights for a 20-to-30 minute nap.
  13. efusco
    19,891
    1,196
    Nixa, MO
    The headlights put a relatively heavy drain on the relatively small battery of a non-SKS Prius II. I think 30 min. would be more than enough time to drain the 12v.
  14. tochatihu
    tochatihu Senior Member
    9,852
    3,814
    Kunming Yunnan China
    2001 Prius
    A pair of 'filament' headlamps should consume about 8 amps (HID less). The capacity of the 12 v battery suggests >3 hours to empty, but any particular battery might get to a no-start level long before that. Especially if the battery draining had happened several times previously.
    There might be other 12 v drains happening, depending on which 'state' the Prius is in. All I know is that it is not in 'ready'.
    This napping might be done better in 'ready'
  15. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    A little recalculation.
    First, the halogen headlamps will draw about 4.5 A each for a total of 9 A. I've measured them. Remember, if the car isn't in "Ready" then the 12V system voltage isn't 13.8, it's the battery voltage (probably around 11.5 to 12), so the lamps draw a little more than you would expect. HIDs draw approximately half that of halogens.
    The stock 12V battery is around 30 to 35 A-hr, so a -fully charged- battery should last at least 3 hours. Even when half drained it should have no problem starting the car.
    I would guess the battery may need replacing, or, perhaps the ground strap is corroded and the battery isn't being charged properly. This is common and confuses people all the time. I suspect 30% of battery replacements (not just Prius but all cars) are replacing "good" batteries and "fixing" poor connections to the battery in the process.
  16. TonyPSchaefer
    14,816
    2,501
    66
    I had to do this for my own verification.
    I went out to Priapus in the parking lot, started him and then shut down. Watching the reflection in the bumper of the car in front of me, I waited for the headlights to shut off.
    I called the experiment off after two minutes.
    I have my headlights on all the time as a "daylight running lamp" thing. As long as I did not open the driver's door, the lights stayed on.
    Therefore, it is plausible that if there were no feedback that the lights were on, no reflection, no high weeds illuminated in the dark, you can sit in a Prius with the headlights on and not know it. Since they are designed to shut off when the driver's door is opened, they will stay on.
    This also explains how I was able to drain my battery a couple years ago. I opened the passenger's door, powered up and plugged in my air compressor to inflate my bike tires. Then shut down, locked the doors and went on a multi-hour bike ride with my wife. The battery was dead when I got in the next morning. Since I entered the car through the passenger door, the "shut-the-lights-off-via-driver's-door" was never triggered. And since it was a bright sunny day, I never noticed the lights were on.
  17. Politburo
    Politburo Active Member
    971
    208
    The 09 has an icon on the dash that tells you the lights are on. No idea if it's on previous models.
    ETA: However if you use the fake-DRL feature, you get so used to this icon that it really just becomes a second READY light...
  18. TonyPSchaefer
    14,816
    2,501
    66
    Can you confirm that the indicator is still on when the car has been powered down. It is not on the '04. I looked.
  19. Politburo
    971
    208
    It isn't. For whatever reason, I didn't consider that.. duh.
    ETA: Now I really feel dumb. I went out just to make sure... and it DOES stay on. However because the dash lights are dimmed (due to the lights being on), it was difficult to make out in the current lighting conditions.
  20. David Beale
    5,963
    1,989
    Edmonton Alberta
    Do note that there are two settings for the dash lights. The car will automatically select the setting you "program". Set them in the sun (daytime) and the car will remember that. Set them at night (dark) and the car will also remember that setting.
    And just to "muddy the waters" a bit, Canadian cars have an automatic headlamp position on the headlamp switch. But the lights do stay on when you shut down and don't open the drives door. But not all the time. I still haven't figured out why they stay on sometimes and not others.
    More mud. The DRLs will stay off when you start the car until you release the parking brake. But they won't go off when you reapply the parking brake!
    I'm getting dizzy! ;)
