62 mph electric mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by jasonneedshybrid, Jan 15, 2012.
  1. jasonneedshybrid
    jasonneedshybrid New Member
    30
    mechanicsville, md
    im trying to get clarification about some of the benefits of the pip vs gen III prius for everyday driving.
    1. 62 mph electric glide. my camry hybrid forces the engine on when i hit 42mph (like every toyota hybrid since my gen I prius). so on back roads where i should be averaging 50, im hitting the brakes down a hill going 40 if im trying to keep ice off and its just limiting. if im driving the pip, even when the ev range is done, am i right that the pip will not do this, where the gen III will?
    2. all electric trips to the post office. my post office is 2 miles from my house. my camry is about warmed up by the time i get home if that's all i did. will the pip let me drive there on all electric, or is it going to wait till she's warmed up before allowing ev mode.
    3. ev mode acceleration. i know the gen 3 prius has ev mode. does the pip allow more power in ev mode since the battery is 3 times larger? or is the acceleration the same, it just allows you to continue to a higher speed/longer range?
  2. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    First, it's 46 mph for the gen III. Second, the early model PHV that I drove reverted back to regular gen III driving once the EV was depleted (back to HV mode).
    All EV baby! That's considering it's warm out. My breakfast run in August, which included a climb out of the valley at 45 mph, never caused the engine to fire up. 0 RPM on the ScanGauge the entire time.
    27 kW is the max draw allowed with gen III
    38 kW is the max draw allowed from PiP
    That alone is a major clue that you've got quite a bit more EV power available. Word from me about my pwn hill climbing experiences should be enough, but if not, just wait another 3 months for video of it. I'm looking forward to showing off that ability.
  3. jasonneedshybrid
    30
    mechanicsville, md
    wow. good info. how warm does it have to be for an all electric short trip? too bad they dont have a plug in prius v :)
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Warm enough for you not to need heat before leaving or on the road.
  5. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    That is quite good - I rarely use more than that in Leaf (when not on freeway).
  6. babybird
    babybird Member
    117
    44
    Colorado
    If I'm remembering correctly, it's 24 kW in the gen II right? Either way, I'm fairly impressed with its electric acceleration when I have 7 or 8 green bars of charge on it and it doesn't want to run the ICE, so 38 kW seems like it'd be just a dandy amount of power! I want one! Need to find a way to afford another couple hundred a month car payment though, or win the lottery or something. :(
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    GenII battery was rated 21 kW and the hacked EV mode could go up to 34 MPH.
    38 kW would be sweet!
