Does 2010 Have Fuel Tank Bladder of Not?
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Jun 6, 2009.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Did a search ... nothing. So strange this topic has vanished.
    So .... Fuel tank bladder or not? I saw something flexible around filler neck.
  2. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    I think it was said on here that there ISN'T a fuel bladder this time around.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No, it does NOT have a bladder. It does still hold 11.9 gallons though.
  4. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Thanks. That's a good thing. :cool: Obviously, I recall this was a big issue and worth putting 'front and center' in a thread.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    You might try a better search:
    [ame="http://www.google.com/search?hl=en&as_q=2010+bladder&as_epq=&as_oq=&as_eq=&num=10&lr=&as_filetype=&ft=i&as_sitesearch=priuschat.com&as_qdr=all&as_rights=&as_occt=any&cr=&as_nlo=&as_nhi=&safe=images"]- Google Search[/ame]
    Tom
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I filled up at 2 pips and got < 9 gallons in. I'm thinking the new fuel gauge is adjusted in such a way that we're less likely to run out.
  7. Tideland Prius
    16,621
    A typical Toyota low fuel warning light will leave about 10 litres in (~2.5 gal)
  8. Steve Cebu
    Steve Cebu New Member
    523
    59
    Concord, NH
    I thought I read that it had a 13.5 gallon fuel tank?
    I'll have to check that.
    Oops it's 11.9 gallons according to the manual.
  9. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    very good news.
  10. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I filled up at 1 pip, after getting a warning chime and the flashing pip. It took about 9.2 gallons.
  11. Tideland Prius
    16,621
    Maybe it's Imp. Gal? It'll translate to 14 Imp. Gal (45 litres)
  12. xsmatt81
    522
    Vegas
    run it nearly dry next time. You can be the first guinea tester for this lol.
    i assume it will fill over 11 gal if you let it run pretty close to bone dry
    let's us know the result.
  13. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Back in the early heady days of the 2004, there were crazy people that deliberately ran their cars dry, just to see what would happen. Since smarter people than me have pointed out that can hurt both your fuel pump and your batteries, I think I'll put that on the list of things not to test, right along with the collision avoidance! :D
  14. patsparks
    10,664
    567
    Adelaide South Australia
    If people are still only getting 9.5 gallons in the tank when the gauge is flashing its warning then we are in for another rash of threads about how you can't fit 11.9 gallons in the tank so people have to visit a gas station 3 more times in their lifetime, oh my god, Nooooo!!
  15. Tideland Prius
    16,621
    Except this time, 9.5 gal is right. We'll have better answers to the "how many miles on the blinking pip?" because there's no bladder.
  16. Sol
    Sol New Member
    Hello, I am new here but I have been searching for the same answer/issue. I ran my first tank down until about half a gallon left and I filled up an only got 9.5 gallons. I thought it was odd because at 12 gallons I expected a fuel range of 600 miles and I'm only able to get 500. The main annoyance is that I'm told it is supposed to be one thing but I'm getting something else.
  17. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    What is happening is that display tells us it is 'empty' when in reality it has about two gallons left inside. If you were to drive at 50 MPG, and use all 12 (11.9) gallons, you would get closer to 600 miles per tank.
    However, if you play it safe, and fill it when the range displays '0' miles to empty, you will be able to fill only about 10 gallons into the tank.
    Annoyed me at first, but actually think it is like a 'hidden reserve' tank, where most drivers will fill up every 10 gallons or so. At the end of the year, you will use as many gallons, but will make about 1/6th more trips to 'top off' the tank.
  18. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    ...and it probably bears repeating that if we play it safe, we also protect our fuel pump, right?
  19. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    2010 Prius III with Navi.
    I filled up at half tank indicated. Slow pump speed on the first notch took 5.035 when it clicked off.
    I than continued to fill it to the very top of the neck where you could not get any more fuel in or it would spill on the ground.
    The pump than stated 7.373 gallons.
    So I believe the 2010 Prius will hold over 11.9 gallons based on all the info I have heard.
    Alfon
