  1. Leadfoot J. McCoalroller
    7,173
    6,721
    Pennsylvania
    2018 Prius c
    We made it to 71,000 miles before our 2018 Prius c two needed its first repair, a wheel bearing.
    The car had a pretty loud hum from 35mph on up. I know, I know, it's cheaper just to teach them the lyrics...
    I paid a neighborhood mechanic to diagnose, then R&R the bearing, about $400.
    First test drive suggests he nailed it.
    How far along was yours the first time it needed something beyond programmed maintenance?
  2. PriusII&C
    PriusII&C Active Member
    370
    129
    San Jose, California
    My 2012 had 110k miles before we parked it in the garage 3 years ago. Besides maintenance services (oil change /10k , air filter / coolant / ATF change once each, 1 set of tire), the only unexpected thing was water in one of the rear light housings. Oh, auxiliary battery was replaced 1 year ago.
  3. Roqu3
    Roqu3 Member
    Lima
    2019 Prius c
    Nothing yet but mine has only 16k km, only thing is that sometimes I have issues with the audio and also sometimes the reverse camera turns black and white in the mornings, I took to maintenance services every 6 months and asked them to check that, they like readjust the cables but after a while it cames back, I think it may be something related to the GPS tracker but I need to take it to the service provider to check that.
  4. toy_yodapriusSeewon
    toy_yodapriusSeewon New Member
    San DIego
    both tail lights have dirt in them,
    replaced head lights bulbs 5xs,
    replaced license plate rear lights 1x
    replaced hybrid battery @ 177,000 ($2200 with 100k/10yr warranty non dealership)
    replaced 12v battery at 190,000
    front brakes and rotors @ 80k @ 225K
    Brake fluid 230K
    Replacing water pumps this month
    ran out of gas once at 210,000 miles. Every light came on and the gas gauge read 2 bars.
    Several ATF and Coolant dump and fills
    oil change every 7500
  5. bisco
    49,490
    2012, 85k, no repairs yet. new 12v, tires, a headlight bulb, oil & filters
