75 K service
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ramapra, Mar 20, 2012.
  1. ramapra
    ramapra New Member
    Foster City
    What should I absolutely do and what should I avoid ?
    I have recently acquired the car ( 6 mths ago) .
    Your experiences will help .
  2. JimboPalmer
    12,470
    6,869
    Greenwood MS USA
    If you have not changed the Transaxle fluid with WS ATF yet, you should do that. Remember when you did it and , do it again in 60,000 miles. (This is not on Toyota's scheduled maintenance anywhere, but will prvent the build up of metal bits in the motor/generators, which short them out)
    Here is Toyota's schedule
    http://www.toyota.com/t3Portal/docu...MS0012/pdf/06omsour/2006/schedmai/61w1smt.pdf
    Page 15 of the PDF
    May be worth while to do a 12 volt battery test while you are thinking of it.
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
