85 vs 87 ethanol in Denver (Not E-85 but regular 85)
Discussion in 'Prius c Fuel Economy' started by Mynewbaby, Aug 9, 2015.
  1. Mynewbaby
    Mynewbaby New Member
    Colorado
    2015 Prius c
    Hello,
    I just got a Prius C and I'm wondering what kind of gas I should be putting in it. I had a Cobalt and put 85 all the time. I think the manual said to put in 87 but I'm wondering if I should stick to 85 since other places I looked explained that this is actually an altitude thing. I'm just curious if this is different because the car is a hybrid.
    Does anyone else own in the forum own a Prius C in Colorado? Which kind of gas do you put in it?
  2. snilloctrof
    snilloctrof Junior Member
    Colorado
    2014 Prius c
    Been using 85 with no problems. Local Toyota service tech saw no concerns with 85. I've wondered what would happen if I went from Colorado east to Kansas and still had 85 in the tank at that lower elevation, fortunately I haven't had to drive to Kansas. ;)
  3. Mynewbaby
    Colorado
    2015 Prius c
    I read if you leave the state with 85 it would cause knocking and some kind of engine issues. I think you'd just have to put 87 in before you went out of state and you'd be okay. Thank you for letting me know.
    I am going to put gas in the car tonight for the first time since I bought the car which was 13 days ago now.
  4. fuzzy1
    10,169
    The car has no clue what U.S. state you are in, only the car's approximate elevation above sea level. Much of Wyoming, Montana, Utah, and New Mexico should handle 85 with no problem whatsoever.
  5. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Lucky you. Engine self-destructs at state line. In case if it doesn't you will not survive: fall asleep and die in horrible crash while looking for Wizard of Oz museum.
  6. coyote303
    coyote303 Member
    112
    64
    Colorado
    I had a recent trip from Denver to Omaha. I didn't think twice about the (85 octane) gas, and I had absolutely no problems.
    wjtracy likes this.
  7. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ..that's what I was thinking all along too
  8. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I drove to Colorado a few months ago - I swear the car got better mileage with 85 - but it was probably all the hills filling up the battery that got me such good mileage while I was there. I fueled up when I departed, and drove through Kansas. I didn't have any knocking issues with that tank.
    JeffMN likes this.
  9. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    That could be quite true if you are comparing to Philly/Lansdale where you are probably in the EPA Reformulated Gasoline region. RFG is basically lower energy content gasoline, so you could easily be getting better MPG outside of home. Here is map. Also octane is not a direct measure of energy content, so you could easily have a 85 octane with good energy content, especially in a non-RFG area.
    Gasoline and Diesel Fuel Update
    #9 wjtracy, Sep 13, 2015
  10. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    do what now? if I read between the lines correctly we are to use 87 or is it referring to E-87 and not plain everyday 87 in the C?
  11. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    High altitude areas use 85 octane for physics reasons which escape me at the moment, octane requirements go down at higher altitude.
  12. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    I live in SE Texas my elevation is about 325 ft. should I be using 87?
  13. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    Yes 87 octane of course Denver is mile high 5280-ft so they get to use 85. You do not have a choice as there is only 87 in the TX pumps.
  14. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    oh yeah 87 is the base octane for me. ok I'm going back to sleep now. :whistle:
  15. fuzzy1
    10,169
    That is one factor. Another is local air density. 85 is sold only areas of low air density (i.e. high elevation), which produces less MPG-robbing air drag.
    With traditional gasoline engines, the lower air pressure also reduces 'pumping loss', boosting MPG even more. But the Prius has already improved that through other means, so has less to gain at high elevation.
    wjtracy likes this.
  16. fuzzy1
    10,169
    I should have added that according to a relative who was blending gasoline at a refinery several decades ago (before RFG), the lower octane grades often had a slightly higher energy content. Thus, as long as the engine was happy, the lowest octane would produce highest MPG.
    But due to various other factors that generally remain unknown to consumers, such as other blending requirements, resource availability at the refineries, and different fuel batches being produced by different refineries at different times, this wasn't always true. And with more factors thrown in the mix today, results may be less predictable now.
  17. fuzzy1
    10,169
    Just a reminder, don't confuse Octane numbers with E- numbers. E85 means 85% Ethanol, which you must not use in regular engines not set up for it. Leave it for the FlexFuel rigs, which doesn't include any Prius to date. Most consumer gasoline is now E10 (10% Ethanol, 90% gasoline) or E0 (pure gas).
    As Wjtracy mentioned, you won't find 85 Octane at fuel pumps in Texas. I usually see it in Montana, Wyoming, and Colorado. It is just fine while driving there, but don't take home any spare cans of it.
  18. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    The manual for my 2015 Prius C states do not use Octane less than 87; the manual states up to E-15 is acceptable and do not use any gas higher than E15 and the gas cap actually has a picture of E85 with a red circle and line thru it means no E85
  19. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    ...fyi this thread is discussing the special case high altitudes where 85 octane Regular is used (equivalent to 87 at low altitude).
  20. JeffMN
    JeffMN Junior Member
    Minneapolis
    I had same experience. Denver was great city for the Prius C (better than Minneapolis). I chalked it up to the hills.
