8A Option in 2020?
Discussion in 'Prime Plug-in Charging' started by Ridgway, Nov 22, 2019.
  1. Ridgway
    Ridgway Junior Member
    I saw several pots that said there was an 8-amp option available for the Prime. I am scanning all the manuals for the new 2020 Prime in the driveway and can't find that anywhere. Is that functionality still available in the 2020 models?
    Ridge (in New Joisey)
  2. Ridgway
    I read several posts that said an 8-amp charging option was available for the Prime. I have a new 2020 and can't find any reference to this in the manuals. Is it still an option in 2020? If so, where will I find the info about it?
    Thanks
    ridge (in New Joisey)
    49,371
    i suppose you already looked through the charging and evse sections?
    Raytheeagle likes this.
    49,371
    only place i can think of discharging and evse usage
  5. yiujai86
    yiujai86 Member
    35
    31
    Miami
    2020 Prius Prime
    Yes its on the 2020. Use the right side steering wheel buttons and navigate the dash menu to the settings icon (the litttle gear icon). Then choose vehicle settings > charge setting > charge current > 8 amp.
  6. Ridgway
    Brilliant yiujai86. Thank you. R
  7. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    See page 132 in the owner's manual. ;)
    MTN and Raytheeagle like this.
