+90F (32C) only 5.8 kWh
Discussion in 'Prime Plug-in Charging' started by bwilson4web, Jun 9, 2018.
  1. bwilson4web
    15,518
    In two hours, we only got 5.8 kWh whereas before we'd seen 6.4 kWh in cooler weather.
  2. Zythryn
    Zythryn Senior Member
    6,252
    4,252
    Charging?
    I wonder if the prime adjusts the maximum charge based on temp? That would be pretty cool actually.
  3. bwilson4web
    15,518
    I don't know as this is my first, hot weather charging session. We had some last summer and they appeared normal. No measurable effect on EV range, yet.
    What pisses me off is the prompt to use AC when charging is only visible for less than 5 seconds when turning off the car. I'm used to this race and have my thumb on the right-hand, roundel, so I caught it. When I came back after getting some groceries, I could hear the AC running. So answering "Yes" works but it is a race (or memory and alertness test.)
    #3 bwilson4web, Jun 9, 2018
    benagi and bisco like this.
  4. Zythryn
    6,252
    4,252
    Interesting. It would be interesting to see if the AC makes a difference in charging speed, max charge, or both.
  5. bwilson4web
    15,518
    I'm struck by how in the cold season we investigated Prime driving performance and now in the hot season, time for another study.
    Speculation, I'm thinking I might use Time of Day charging to allow power charging between 10-12 PM through 9-10 AM. To be more useful, I need a concurrent battery temperature measurement which may be tricky.
  6. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    I charged by plugging into a Kill-A-Watt meter last night and it took 6.48 kWh. Temperatures in my area are highs upper 90s and lows in the upper 70s.
  7. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I thought KWHr useage was just that. Amount of electric power required to fully charge Prime.
    If so, this indicates less required power needed in hotter temperatures than cooler. There’s not a
    relation to Miles charged or miles used, there are other factors involved there.
  8. bisco
    49,448
    battery won't accept as much charge? computer won't allow it?
    Andyprius1 likes this.
  9. Andyprius1
    2,327
    859
    Cool CA
    Who knows, Toyota will not divulge.
  10. bisco
    49,448
    secretkeepers.
  11. Zythryn
    6,252
    4,252
    Thus, the questions and testing :D
  12. Ray Moore
    Ray Moore Active Member
    857
    52
    Texas Hill Country
    I just bought a new Prime. It is so cool to see some of the same people hear discussing these topics of the newest Prius technology 14 years after we had the same discussions about my '04
    breakfast and Andyprius1 like this.
  13. Andyprius1
    2,327
    859
    Cool CA
    True, the 12V will never die.
  14. bb4srv
    bb4srv Active Member
    140
    106
    2018 Prius Prime
    Technology
    I have a canadian model 2018 Prime. The "Use AC for Charging" doesn't disappear in mine. Sometimes I turn off the vehicle and I see that notification, and it doesn't go away. I have ample time to select "Yes"
  15. Andyprius1
    2,327
    859
    Cool CA
    On mine it’s very fast, it only took 18 months to do it.
  16. bwilson4web
    15,518
    So after running the battery down to ~2%, I waited until a local shower reduced the temperatures to ~75F:
    • 5.55 kWh / 98% ~= 5.7 kWh
    Not definitive but curious. I'm seeing the same input charge as at the higher temperature. A longer cold soak might have a different result.
  17. Andyprius1
    2,327
    859
    Cool CA
    That’s awfully cold rain in Huntsville!
  18. bwilson4web
    15,518
    Stronger reading glasses my friend, "~75F".
  19. Andyprius1
    2,327
    859
    Cool CA
    Ah so, so solly.
    bwilson4web likes this.
  20. bwilson4web
    15,518
    Charging in 90-95F temperatures:
