  1. Leksvndr
    Leksvndr Junior Member
    Hi everyone
    The official dealer offered a service at 90k worth more than $ 1000. After I removed all unnecessary options, 400+ came out.
    As I understood the main thing is the replacement of engine oil and transmission, replacement inverter coolant.
    what else? what to els? Of course I will replace the air filter:)
    Perhaps there is already not one similar topic, but I have not found it. excuse me)
  2. Leksvndr
    noticed that sometimes the engine shakes slightly at idle
  3. Leksvndr
    Oops, completely forgot this prius 2016
    49,500
    welcome!
    you don't change the inverter coolant at 90k
    follow the maintenance schedule toyota provided with your car
    90k = oil and filter
    check/clean/replace air and cabin filter
    tires rotation
    total inspection and brake lubrication
    consider tranny fluid swap
    engine shaking at idle might be throttle body or maf sensor
    Leksvndr likes this.
  5. Mendel Leisk
    38,730
    Look in the glove box for the Toyota USA Warranty and Maintenance Booklet, it outlines what needs doing. You can also download a pdf, from Toyota Tech Info (the manuals section), for one. Page grab from page 49:
    The highlighted ones are what's crucial.
    #5 Mendel Leisk, Jun 25, 2019
    alanclarkeau and Leksvndr like this.
  6. Mendel Leisk
    38,730
    ^ Addendum to the above: The brake inspection also is important. It's the third in-depth brake inspection spec'd by Toyota (every 30K miles); at other intervals it's just "visually inspect", basically just a look-over during tire rotations.
    And of course, dealership said nothing about brake inspection???
    #6 Mendel Leisk, Jun 25, 2019
  7. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    There is zero need to measure rotor runout or rotor thickness if the brakes are working fine, especially on these cars. Asian vehicles which use an adhesive friction system do not wear the rotors very much at all.
    If the brakes are working normally with no vibration, the runout is low enough that it is not causing disc thickness variation.
    The only time you need to measure rotor runout is when doing a brake job. @Raytheeagle is now an expert at it.
    Mendel Leisk and Raytheeagle like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I guess we’ll put my “expertise” to the test next weekend:).
    The brake job is required on this old corolla:eek::
    65B6E663-86E5-405D-BDF8-586DA795622C.jpeg DEF6B521-4295-40BB-B5B4-EE1EAF00308A.jpeg
    Hopefully I’ll look as professional performing the task(y):
    The Critic and Mendel Leisk like this.
