91 octane ethanol free
Discussion in 'Gen 3 Prius Fuel Economy' started by bulajap, Oct 29, 2015.
  1. bulajap
    bulajap Junior Member
    Niagara Flls
    Hi everyone,
    I have a 2012 Prius ( Model 4). I have been using 87 octane, unleaded, ehtanol added gasoline.
    Is it safe and to used 91 octane, unleaded, ethanol-free gasoline? Would it be better for the vehicle?
    thanks
  2. Mendel Leisk
    42,077
    If that's your only option to try ethanol free, sure I'd try it. It won't damage anything. Up here the only ethanol free option I've seen is chevron's TOP octane. Never tried it.
    Higher octane gas is really only needed for a small minority of cars, typically with higher compression engines. Even then, if they're filled with 87 the car's computer will sense knocking and retard timing a bit.
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    I tried it, a while back, and my mpg went up 4mpg. However, if you use 10 gallons before refueling, it comes out to less than a gallon of gas saved. The price premium works out to double what you save, so it really isn't worth it, economically...
