95K maintenance- should I get an oil change?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by southtxprius, Apr 5, 2016.
  1. southtxprius
    southtxprius Junior Member
    78
    South TX
    My 2010 Prius just turned over 95K miles. I've been doing the 10K oil change interval with no noticeable consumption between changes, but the vast majority of my driving trips are 3mi or less. Should I switch to oil changes every 5K? According to Toyota, this doesn't fall under the "severe" use category since these short trips are in moderate or warm temps.
    The 95K service is light: $28 for tire rotation, visual brake inspection, and fluids.
    Balancing the tires would be $39.95 extra, and a synthetic oil change $83.95 more.
    I could go to Discount Tire for free rotation and balancing, but they won't look at the brakes.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Would you feel happier if they had the $83.95 and you didn't? The car will be happy with 10,000 miles/12 month oil changes.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Damn that is some expensive maintenance... I would do this all myself and save me all that money. Honestly, you should still do the 10k miles oil change, no need for 5k and wasting all that money on oil. Also you shouldn't worry about the brakes since mine is at 100k and the brake pads are not even half worn. Balancing your tires are a waste of money unless you feel vibrations at 65+ miles on the highway. Also I rarely do tire rotations, each time you do tire rotation, it cost you 28$, you can save that for brand new pair of 4 tires in 2-3 years for 500$-600$. That's just my opinion, most of these you can do it yourself and you're a DIYer, if not, then just pay I guess...
    49,482
    how much oil are you burning between changes?
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    This is what I did when the 95k service light came on 2 weeks ago.
    1. Change the display to Trip A
    2. Hold mph/kph button while holding the start button to start the car
    3. Hold until maintenance light turned off.
    I expect the light to turn back on at 100k miles and then I will change the oil and rotate the tires.
  6. southtxprius
    78
    South TX
    None as far as I can tell. The level on the dipstick stays at full. I check the level fairly often.
  7. southtxprius
    78
    South TX
    So the fact that the majority of my trips are under 3 mi should not be a concern re: oil change interval?
    I'm a bit of a DIYer: easy stuff- wiper inserts, air filters, lowbeams and side marker bulbs, turn signal lens, bumper clips and door lock. Bought the car used, so I inspected the hybrid battery fan as well, but I'm not currently equipped to do oil changes or tire rotations myself.
    I've had issues in the past with the brakes (rear calipers sticking, etc) and was told at the 90K service that the front pads are getting close to being worn. I've gotten free tire rotations & balancing at Discount Tire, and Midas will do brake inspections for free, so I may go that route.
  8. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I follow the 6 months or 10k miles interval. I did that with my Honda Accord as well and haven't noticed any difference in my oil. I've gone as far as 8 months without an oil change and my Honda still runs fine. I don't see any oil leaks or change in engine performance either.
    Since you bought your vehicle used, I would just do all of the required maintenance such as all the fluids, lube the sliding pins for the front and rear brakes, also inspect the inner and outer brake pads. Change all filters if necessary and anything else on the maintenance list. You want to know you that did everything so you have a peace of mind.
    ScottHz likes this.
  9. bisco
    49,482
    i would stay with 10k changes then, you should be fine. if you are concerned, you can send your used oil out for testing.
  10. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    The 10K oil changes require synthetic oil and a filter as well. It's easy for sleazy mechanics to use standard oil and/or skip the filter in order to make more profit.
  11. Mendel Leisk
    38,723
    I don't see anything in the Owner's Manual, or the Warranty and Maintenance Booklets (US or Canadian) to corroborate this. Most if not 0W-20 is synthetic, so really a moot point. But Toyota doesn't make any statements to the effect that the 10,000 mile oil change interval is tied to the use of synthetic oil.
  12. southtxprius
    78
    South TX
    Thanks All! I will continue with 10K oil changes. The last dealer charged $53- much better than what I saw online a few days ago.
  13. Rebound
    3,964
    2,613
    Portland, OR
    Really? I thought for sure the standard was to use synthetic, and the Toyota oil is a synthetic. As you say, maybe synthetic is the only possibility, but I'd always assumed that it was a requirement for 10,000 miles
  14. Mendel Leisk
    38,723
    It says in the 2010 OM, if you use 5W20, switch back at next change, but no mention of sooner. No mention of synth either, tho both grades likely are.
  15. NutzAboutBolts
    1,476
    1,552
    Bay Area
    5w-20 can be non synthetic...
  16. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Don't change the oil. Get a new Prius four touring instead. I saved $65.:ROFLMAO::LOL::cool:
  17. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    ... which I suspect is likely the other main reason (besides fuel consumption) they specify shorter change intervals with 5W-20, not that synthetic 5W-20 is likely to harm the engine. That way, they avoid confusing naive customers with discussions of synthetic vs. mineral oil.
  18. Mendel Leisk
    38,723
    Where do they specify shorter oil change interval for 5W20?
    (I'm not trying to debate, just haven't found that anywhere, so far.)
  19. Rebound
    3,964
    2,613
    Portland, OR
    ScottHz likes this.
  20. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    In my 2011 Warranty and Maintenance Guide (USA edition), every X5,000-mile maintenance item list includes a highlighted "Note: If 0W-20 oil WAS NOT used at the last oil change, replace engine oil and oil filter." Page 570 of the Owners Manual states "If SAE 0W-20 is not available, SAE 5W-20 may be used. However, it must be replaced with SAE 0W-20 at the next oil change." That seems pretty clear, whether we agree or not.
