P0A93 code
Discussion in 'Gen 2 Prius Main Forum' started by PA Prius, Mar 11, 2011.
  1. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    2004 with 146,000 miles. Today I was taking my daughter to the airport for her international flight when the red triangle came on, along with the check engine and a few other random lights. Also "Problem" was prominently displayed across the top of the MFD. I checked the code on the Scanguage and it showed P0A93. I see on other posts here that it could be inverter related. I cleared the code and was able to drive the 18 miles to the airport and the 70 miles home. A few questions--
    1) When a code is cleared, will it appear immediately again if the problem remains. In other words, is it okay to clear a code and continue driving?
    2) Related to the above question - is it okay to drive now or am I risking further damage?
    3) Is it correct that Toyota will cover the replacement of the inverter water pump as noted here--
    Luscious Garage | Blog | Toyota Prius Inverter Water Pump Recall
    4) If Toyota does cover this, I am assuming it needs to be done by a Toyota dealer and not an independent shop, right?
    5) How can I tell whether it is just the pump that is bad or if the inverter has been damaged?
    6) I still had the full grill blocked, top and bottom, outside temperature was 45° F. Is that a problem?
    Thanks for any help!
    PA P
  2. Patrick Wong
    18,200
    6,474
    DTC P0A93 "Inverter Cooling System Performance". This is telling you that the inverter has overheated.
    1. In this case it was not OK to clear the DTC and continue driving because the inverter is in distress. I would suggest that you either let the car cool down for an hour or so; or else find a convenience store, buy a bag of ice, and place the bag on top of the inverter in hopes that will help to moderate its temperature. Given your #6 above, at minimum remove all grill blocking.
    2. It is not OK to drive the car any significant distance while the inverter overheating condition persists, unless you are trying to destroy the inverter.
    3. It is true that 2004 to certain 2007 model year Prius are eligible for an inverter coolant pump replacement under the limited service campaign currently in effect.
    4. A correct assumption on your part.
    5. If the car will become READY then the inverter is OK. Look at the fluid in the inverter coolant reservoir. If the pump is running then you should see turbulence in the fluid.
    6. I would remove all grill blocking. Certainly that did not help the inverter overheating situation. It is quite likely that without any grill blocking the inverter would perform fine at 45 degree F ambient temp, without a functioning inverter coolant pump.
    PriusCamper likes this.
  3. PA Prius
    754
    241
    SE Pennsylvania
    Thanks Patrick,
    Yes, I did remove the grill blocking immediately yesterday.
    The READY light does come on this morning, as it did at the airport after having driven 18 miles and sitting an hour. I do not see any turbulence in the inverter cooler fluid container with the ICE running but cold. Additional questions--
    a) Does it need to be warm for the pump to be running (thermostat based?) or should it be running all the time? including in battery-mode?
    b) Since the READY light comes on, does that mean all is well?
    c) Does clearing codes "de-activate" the [reporting to the] ScanGuage for a certain amount of time or miles? Would this also effect the READY light coming on, i.e. the READY light comes on even though all is not well since I cleared the codes.
    PA P
  4. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Not totally sure about the temperature, but you don't need the engine running to see the turbulence in the inverter coolant reservoir. When I tested mine a few weeks ago the car was in "ready" mode but the ICE was off and I could still clearly see the turbulence to indicate that the coolant pump was running.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Yep, as long as the pump is good, and the system is not airlock, you will see turbulence in the reservoir, in Ready and possibly even in IG-ON.
    The only way that the car knows that you have a dead inverter cooling pump is when the inverter coolant gets overwarm. Since you have reset the code, the car believes that everything is OK and will operate normally. By removing the grill blocking, you could conceivably drive for a few more months before summer temps get things hot enough to trip the alarm again. But you should get it to a dealer as soon as possible -- and there is little risk in driving it to the dealer.
  6. Flying White Dutchman
    4,374
    313
    drive the same direction and with the same temparature and see if its overheats again
    YES ;-) with a full grill block
  7. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Why? He's already said that he can't see the inverter coolant pump turbulence so it would be foolish to drive it in a manner that risks overheating it again.
    Just get the inverter coolant pump fixed as soon as possible.
  8. Patrick Wong
    18,200
    6,474
    a. The inverter coolant pump should be running at all times when the Prius is either IG-ON or READY.
    b. This means that your inverter is still working, but all is not well since the inverter coolant pump is dead.
    c. There's probably some time lag before the hybrid vehicle ECU logs the inverter overheating DTC.
    As your car is no longer under warranty and you would be responsible to pay for replacement of a failed inverter, I encourage you to make it a priority to have the inverter coolant pump changed sooner vs. later, and to drive the car as little as possible, prior to this repair.
  9. PA Prius
    754
    241
    SE Pennsylvania
    Your comments are very helpful, thanks. I just drove miles. Outside temp 55°F and rechecked the inverter fluid. I still don't see any turbulence there. I also stuck my finger in and the fluid is cold.
    I'll try to get an appointment at a Toyota dealer ASAP. In the mean time, are ten mile trips okay, or should I really not be driving? I did drive the 70 miles back from the airport yesterday.
    PA P
  10. Patrick Wong
    18,200
    6,474
    On the one hand, since the inverter survived a 70 mile trip, you would think that it should survive 10 mile trips.
    On the other hand, should the inverter fail after one of these 10 mile trips, please do not say that no one warned you against driving the car. It's really up to you and your preference for risk taking vs. risk aversion.
  11. PA Prius
    754
    241
    SE Pennsylvania
    You are of course correct. I do have a request in at the local Toyota dealer for a service appointment ASAP.
    PA P
  12. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I expect you mean the fluid in the reservoir is cold... without the pump moving the fluid I'm not surprised... the fluid in the inverter I expect is not cold.
  13. karoo
    karoo first time owner
    17
    LArgo Florida 33771
    2001 Prius
    Hello every one!
    I am the proud owner of a 2001 1st Gen Prius. Finally after 115,00 trouble free miles the Triangle of death came on my data screen. A trip to Advance Auto revealed a code of P3130. "Inverter coolant system malfunction". OK.... So after help from these pages amongst others I found many interesting things. 1) That no fluid flowing through the Inverter cooling reservoir when the key is at the second position regardless of engine temperature is a bad thing. 2) The driver side of the bumper has to come loose. 3) Removal of driver side front wheel and front and bottom portions of fender aprons and splash guards is necessary before the fender can be loosened, enablening you to remove the drives side headlight. After you seperate the FENDER from the bumper where they meet. 4) Getting the air out of the pump to get it to flow was the biggest headache!!
    Now you can see the pump and replace it! I was able to successfully remove and reuse the original hoses and clamps. The biggest problem I had was bleeding the air out of the hoses and pump. My last resort finally worked restoring coolant flow and turbulence through the reservoir. I positioned the pump as low as possible and upside down while still hooked up beneath the inverter. BE SURE TO REMOVE THE SERVICE PLUG FROM THE TRACTION BATTERY in the trunk. Kneading and shaking the hoses and pump until coolant flow is detected in the reservoir. Reassemble after bleeding all air from the system through the two bleeder fittings on the small hoses. Finally I erased the codes by disconnecting the aux. battery for about 35 seconds.
    prius2serve likes this.
  14. Patrick Wong
    18,200
    6,474
    I'm glad to hear you were successful with the inverter coolant pump replacement.
    There is no need to remove the orange traction battery interlock switch since you were not exposed to the high voltage cabling. However if it made you feel better to do that, then no worries.
    [email protected] likes this.
  15. karoo
    17
    LArgo Florida 33771
    2001 Prius
    Well Pat, I had my arm up against those three orange Cables coming from the inverter and since they are the same color as the service plug I took the prudent step to disable the HV battery. I must admit though, when I was trying to bleed the air out of the blasted thing while it was running I did have my forearm and wrist against those orange cables. As we can see I lived to tell about it without incident.
    I would feel awful if some one were to get fried even though I might just be "lucky".
