A better and stronger plastic "push rivet" oil change door clip...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mike500, Mar 24, 2012.
  1. Mike500
    Mike500 Senior Member
    2,593
    766
    For all of those, who have had trouble with the plastic "push in" plastic rivet type fasteners used for the oil change door, I pleasantly discover, by accident, a much stronger fastened of the same type, when I roder the 10mm ones on eBay from Hong Kong.
    I got these, today, and I am very well pleased. They have much stronger metal inserts.
    eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
    If you look closely at the photo, you will notice the metal insert below the button and out one of the sides in the expanding legs.
    While this will be an exact fit for the large rivet, they can be used for the holes using the smaller rivet, simply by enlarging those holes with the correct sized drill bit.
    I also like the idea that, with this modification, all of the plastic push in rivets will be the same size.
    And, the price is goot at less than $7 delivered. The only downside is that it took 2 weeks to get them.
    3 people like this.
  2. cobradb
    cobradb Member
    105
    tn
    this is good news, i too have had it with the o e fastners
  3. Mike500
    2,593
    766
    I looked at them, again.
    There are two "L" shaped metal inserts with "claw" that is pushed out the side on two opposite expansion elements of the four, when the pin is pushed it.
    I noticed how weak the large OEM clip with the gray center was, when I removed it. I was not sure that it could retain the cover door too well. So, I am glad that I found a much stronger alternative and am able to share it with other Prius owners.
  4. Mike500
    2,593
    766
    These are probably the best for the smaller 8mm ones that Toyota uses for the main bottom engine cover;
    The OEM ones depend on the frictional surface between nylon and nylon for retention.
    The ones with the screw are "ratcheting" in that the screw ridges and valleys "grab" each other and help prevent "creeping" slide out of the center push pin.
    The screw ones need the Phillips screw to be taken out to be crmoved.
    I noticed that the Toyota mudguards used the screw center push rivets for their greater holding and retention power.
  5. cobradb
    cobradb Member
    105
    tn
    these clips too large for 2010
  6. Mike500
    2,593
    766
    As
    Please read the original post carefully.
    I stated in my original post, the one larger clip is correct. The others are 8mm. The holes would have to be enlarged to thake the larger 10mm clip.
  7. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    @ Rude person's...
    Thanks for the link on the rivets- mine arrived the other day. They seem much more robust than the all plastic OEM Toyota rivets.
    BTW- I've been using a flat head screwdriver to pop the top and diagonal pliers to pull the body from the hole. That method seems very amateurish to me- is there a specific tool or better method to accomplish the task of rivet unlock and removal?
  8. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I use the same flat head screwdriver technique, except I pry the body out with it, too. I've often wondered about getting some coarse thread screws to put into there instead. Knowing we have 8mm and 10mm openings, that might be a good option. Maybe get one of those plastic deals that clip onto an area to hold the screw into place. Hmmmm, might be time to check out the local Home Cheapo or Lowes for something to put together......
    I've seen someone use a tack remover or something like that. Basically, a wide flat head with a gap in the middle.
    These things, with some screws should work well for a lot of them, I think:
    http://www.clipsandfasteners.com/Toyota_U_Nut_14_Screw_Size_20mm_X_29mm_p/a14276.htm
    That website also has tons of fasteners, and maybe another option for ordering them.
  9. Mike500
    2,593
    766
    TsKarma and Den49 like this.
  10. ny_rob
    1,968
    813
    L.I.- NY
    Thanks again....
    Harbor Freight just opened a store the next town over- Guess I'll bring one of the new rivets with me and see what they have that will work.
    -Rob
  11. El Dobro
    El Dobro A Member
    7,075
    3,258
    I used one today to remove the entire bottom panel to do an oil change and look around under there.
  12. Den49
    Den49 Member
    498
    269
    Maryland
    Thanks to Rude person's for identifying the Harbor Freight 67400 "Push Pin Pliers". I received mine yesterday and tried it on a few push pins. It works great, much better than a paint can opener or screw driver. With the pliers it is now an easy one-handed procedure: grab the push pin head, squeeze the pliers and pull it out.
  13. Bullydog
    Bullydog Meus Prius
    Tennessee
    Thank you Mike! I just ordered a set of the 10mm rivets and I will drill out the smaller holes to make them all the same size. Also, thanks for the info on the pliers. I have a local Harbor Freight store near where I live. I will stop by this weekend to get a set of the rivet pliers.
  14. gliderman
    gliderman Active Member
    751
    225
    Be prepared to wait. I ordered a set over a month ago and they just say to keep waiting. For $6.99 its almost not worth fooling with, but I will wait another week. Patience....
  15. has been
    has been vote for anyone except Trump
    254
    46
    pacific n'west
    Tacoma Screw, Fasteners, Inc., places like this IN YOUR OWN HOME TOWN or close locale will be able to provide you with all of this type of thing.
    Buy local!
    Save your own town!
    Rebound likes this.
  16. gliderman
    751
    225
    I ordered in April and they never arrived. They wouldnt give me a refund, said to keep waiting. $6.99 isnt much but I had to get Paypal to refund. I wont let anyone take my money without recourse. Bought what I needed at local auto supply.
  17. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Just a quick update. I ordered the $6.99 large push pins from over seas.
    I used them on the large holes only for the oil change door. They fit more snug but after 6k miles I did my oil change and I had trouble removing them with a screw driver. My fault because I did not have a tool. They broke in pieces from being very brittle. I suspect from outdoor exposure and lack of the correct tool.
    I am going to try the Napa ones next and get a pin removal tool.
  18. Mendel Leisk
    40,586
    Paint can openers are also good with these fasteners.
  19. gliderman
    751
    225
    No wonder every painter I hire is a drunk. Look whats on the other end of the paint can opener!
    The can opener/bottle opener is probably the first popular multi-tool invented.
    Back on topic, I bought a push pin removal tool from Harbor Freight and seems like it was about $6 with the 20% coupon. Works great!
