A Better Mousetrap!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ekpolk, Jan 30, 2007.
  1. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    I hate bad wipers. I've always felt that the frame-with-refill design that predominates on cars today is a poor, just-good-enough solution that's not really good enough. Anyway, a few months ago, we replaced my wife's Sequoia with an 07 Avalon XLS. It's a great car in many ways. One thing that stuck out right away is that it comes with the new design "structureless" wipers. The wiping pattern is perfect from one tip of the blade to the other. These blades create no pressure point streaks at all, and leave nothing but clean bare glass behind them.
    A couple weeks ago, I noticed that Autozone was carrying a similar design by Bosch. The product line is called "Icon". I immediately got a set for the Prius, and they are great. Other than the goofy floppy look when you raise them for cleaning, it's a noteworthy improvement, at least IMO. Here is what they look like. The snap on easily. Note how well integrated they look:
    If you're due for a replacement, try these!
  2. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    Thanks for the INFO.
    The Prius blades are not bad, but I also hate bad wipter. My wife's focus as terrible wipers. I will look to see if we can get her a set of these, and when it's time to replace my blades (should be soon) I will try them as well.
    How much are they?
    /Robert
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I have always hated bad wipers, like Somerville said. For some reason, my passenger wiper leaves a streak in the outer-most few inches. I say that FireEngineer has these Bosch wipers and he said they are good. This is the second time someone has suggested them so I will pick up a pair.
  4. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(SomervillePrius @ Jan 30 2007, 10:55 AM) [snapback]382821[/snapback]</div>
    Robert:
    My apologies for the lack of precision, but it was in the twenties for the big one (26" size, which is spec) and low teens for the smaller passenger side (spec is 18", having measured carefully, I cheated and used a 19"). A little pricey, but worth the improvement to me.
  5. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Tony's right I've had my Icons for about 8 months. Worked great until the past month. The passenger side blade leaves a 3 inch wide streak right under where the blade attaches to the arm. Really annoying :angry: . I've tried bending the blade so the ends do not exert as much pressure but it does not seem to help. If it was on the driver side I would have ripped the blade off by now and put the Toyota original back on.
    Wayne
  6. ScottY
    ScottY New Member
    1,250
    Long Island, NY
  7. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(FireEngineer @ Jan 30 2007, 12:55 PM) [snapback]382887[/snapback]</div>
    Uh-oh. I thought I'd finally found a truly better solution. Of course, since I have them installed, I'll leave them be and see how long they work for me. OTOH, I've never really expected super long life from wipers, but at this price, I'm still hoping for better.
    If I don't do signicantly better, perhaps I'll try a set of those silicone blades Scott mentioned, above. Michelin also makes a "structureless" model as well, which depending upon price, might be worth a try. From both the look of the Bosch's new performance, and just thinking through the physics of the design, the structureless design would seem superior to existing frame designs, but this is just my theory.
    I'm a little gunshy of coatings. I've tried various products like Rain-X and so forth, and ultimately, most of them have led to unacceptable chattering problems or have been insufficiently durable. I'll be interested in seeing how Scott's blades (and the coating) perform in the long run.
  8. kdailey356
    kdailey356 New Member
    111
    The BMW and Land Rover came with them standard, and i have to say, i like the prius wipers better over all... they are quieter. It might seem weird but thats just what i have experienced.
  9. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(CapeCodPrius @ Jan 30 2007, 01:46 PM) [snapback]382917[/snapback]</div>
    As I noted in the original post, they come standard on the current Avalon as well. My wife's 07 Avalon has them, and one of the things I like so much is that they're almost completely silent. I surmise that they work better in some installations, not so in others. I hope I have better luck with longevity than Wayne did. . .
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(ScottY @ Jan 30 2007, 02:04 PM) [snapback]382894[/snapback]</div>
    How do I get it shipped for that price? I have their 26" and want to get only the 18". I used them on my previous car and loved them. They last much longer than OEM stock Toyota wipers.
  11. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Do they still have free shipping? When I order mine, they had free shipping.
  12. txav8r
    txav8r Senior Member
    43
    DFW, Texas
    <div class='quotetop'>QUOTE(ekpolk @ Jan 30 2007, 01:19 PM) [snapback]382904[/snapback]</div>
    I have used Rain-X for over 5 years on various cars from Honda Odyssey, Chevy Silverado, VW New Beetle, and now the Prius. I could not be happier with that product. I only have to use my wipers when in slow traffic under about 30mph with only drizzle. Otherwise, the rain beads and sheds like magic. The result is the wipers last forever unless direct sunlight while parked bakes them dry. I have not noticed anything but improved function of the wipers on a Rain-X windscreen. Try Rain-X. Yes, you have to reapply after several washes. If you clean your windscreen with clean water and your hand, you will increase time between applications. I would not drive without it.
  13. vinnysca
    vinnysca New Member
    200
    I too bought the Bosch Icon wipers for my Prius recently. Just a word of advice...when following the Bosch book as a reference for wiper size, do buy the 28 inch long wiper for the left side. The book will recommend a wiper with a shorter length. The 28 incher will have a wider wipe coverage.
    Vince.
  14. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(txav8r @ Feb 4 2007, 01:35 PM) [snapback]385189[/snapback]</div>
    I started using Rain-X (authentic Rain-X) back around 98-99. I fiddled with it for years, and could never keep it from getting sticky, and causing the wipers to grab and chatter horribly when I needed to use them. I agree that medium to high speed, the fresh Rain-X effect is amazing. I know others have liked using the stuff, but I could never keep it from getting sticky. I don't know if it was the local bugs, the blades I used or what, but the chattering would get so bad that I feared it would damage the wiper system. I also experimented with Rain-X brand washer fluid, but if anything, it caused me even worse blade sticking than original Rain-X. If it's working for you, great, power to you, but I struggled with the stuff for five years, on and off, and finally decided it was not worth it.
    My later experiments have shown that what's more important than what you put on the glass is what you take off of it. If you use a mild abrasive cleanser (like Bon Ami or Soft Scrub), you get the glass so clean that it will bead water all by itself, almost as well as Rain-X, but with no sticking. A couple of car makers actually endorse the use of Bon Ami on car window glass.
    <div class='quotetop'>QUOTE(vinny @ Feb 4 2007, 06:12 PM) [snapback]385293[/snapback]</div>
    I took that a step further, and put a 19" blade on the right side too. It's only an inch larger than stock, but the pattern covers more area and looks much better (if you care to notice...). Good call.
