A/c and camping out
Discussion in 'Gen 2 Prius Technical Discussion' started by abra, Jun 2, 2008.
  1. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    next mo im going camping for one night. going to be sleeping in the cargo area.
    with a/c and car on how much fuel should i accept to use over a 6hr time period?
    temp outside should be 80 with 100% humidity
    hotel cost 60 a night, i thinking about 12-18 in gas
    side not
    my ion used 5 gallons overnight in same condictions
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I did a quick calculation assuming that the AC will run at about 50% of capacity (about 1.6 kwatts), add a like amount for powering the rest of the Prius electronics, and the Prius utilizes about 25% of the energy in the fuel. I got about 2 gallons in 6 hours.
    Remember to leave your Prius in "Ready" mode and in "Park" (not neutral) so the ICE can cycle to keep the traction battery charged.
    JeffD
  3. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    I wouldn't accept any fuel use overnight. Is the overnight temperature still 80? What's wrong with sleeping in a tent?
  4. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    1.have no tent
    2.allergies
    3.evertime i sleep in a tent it storms or heavy dew
    4. no time to setup or break down
    5. to much time to set up camp for a 1 night sleep
    plus no garinty that i will be sleeping out, may just drive to a friends house.
    its a just incase i drink
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    How much time and/or electronics savvy do you have? You could
    whack together one of these, and at least have ventilation without
    bugs or rain coming in.
    Recently I've also had the untried idea of tossing a big piece of
    mosquito netting over the entire car, coming up with some way to
    enter one of the doors without disturbing it too much, and cracking
    the windows. Creative padded weights around the perimeter or
    something to keep it on. Presumably some weatherguards would
    allow that in wet weather, too.
    _H*
  6. Neicy
    Neicy Member
    834
    Wakefield, MA.
    I have done it but usually it's a little heat that I need. I have the rain deflectors, so I can just leave a window cracked, car in ready mode locked from the inside, fan on low and music to sleep by. I have seen very minimal fuel usage this way. Without the sun heating up the car I think you will find you don't need to crank the A/C, probably just enough to keep out the stuffiness. A lot more economical than paying for a hotel room when all you really need is the shower.
    I don't do tents or bugs:D.
  7. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    I really doubt that the Prius will use anywhere near that amount. I've left my car in Ready for the air conditioning (dog in car), and I guessed that it cost maybe $0.25 for an hour. It was so little that it was hard to calculate. Be sure to set the parking brake and press the Park button. And lock the doors...
    You'll probably want to turn off the MFD. Press the Display button, and then the "Screen Off" selection. Press anything else to get it back.
    You can block most of the light from the speedometer by placing a piece of paper flat on the dash in front of the display. The display that you see is just a mirror - the actual image is projected up from the dash.
  8. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    camping and bugs i dont do either.
    ebrake will be sat, a/c will be at 74-76(just anough to keep the sweet off)
    dimmer on control will be down/ display off.
    wish there was a plug in for the a/c and heat to run off 120v
    thankyou for your input.
    btw a full size 1 in memoryfoam pad is so much faster then a tent (trim to fit arae)
  9. timm
    timm Medical Transport Driver
    121
    Spring Green, WI
    Four Touring
    Does a person need to worry about carbon monoxide poisoning while sleeping in a Prius with the windows up and the engine running?
  10. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    Its something to consider, but with the engine only running for short amounts of time, I don't think its a risk.
    When sitting on a really warm day in the sun, I had the A/C going while making a call. I was in the car sitting for about an hour. I forget the exact timing, but I think the ICE turned on for about 2 minutes when I droped to 2 bars. I think the battery then was good for 5 minutes or more. It repeated this way pretty consistently.
    I'd think at night when it should be cooler, it shouldn't need to kick on as frequently. I think I also had my temp set around 68-70.
  11. Bob64
    1,540
    92
    Virginia
    That risk can be mitigated by telling the prius to use outside air...
  12. Ailu
    Ailu Prius Groupie
    110
    Sierra Nevada Mountains, CA
    So am I understanding this right, that if you have the car in "Park", powered "On" and "Ready", then you can run the air conditioning, electronic items using the 12v plugs and the like, and the ICE will keep the battery from ever going dead?
  13. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Exactly! (until you run out of gas)
  14. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Isn't this a wonderful little car? :D
  15. Ailu
    Ailu Prius Groupie
    110
    Downright amazin! :rockon:
  16. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    camping sound like more fun :D
    i thought about the exhaust to, i have some exhaust piping in storage that i used in the garage on my cars in the winter. ill bring that (6ft lenght)
  17. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    Then again, you could always use some duct tape and mosquito netting to make a screen window. Just be real quick getting in and out. A pet dragonfly or three would be pretty useful, too. :cool:
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    oo.. oo.. pick me.. pick me..
    i've been camping out with my prius for a while now. Once a week. My parents have a motor home. I connect the prius to the motor home.. this way we can run what we need off the motor home's 12v system. I privide audio out of the prius. Around midnight.. or one.. or.. two... I'll set up my bed in the car and turn the auto climate on with the fans set to low. I find that ground circulation works best. It turns into a bed warmer.. hehe..
    anyway... with around 10 gallons of fuel.. large tires.. and agressive driving.. i managed 34mpg... *blink* *blink*.. i get 35 to 40 normally. With the car running 30 hours or so.. with the hood up, so the a/c fans don't kick on. ;)
    I assumed i used a gallon to two of gas... i wasn't driving as aggressive for that trip... i was expecting to break 40.
    so.. 320 / 40 (expected) 8 -10 (estimated gas) = -2 (gallons missing of fuel...
    so.. compaired to 320miles with 34mpg driven.
    so I'm left with 15 hours per gallon of fuel.. but that's not exactly accurate.... motor home lights are.. what? 20 watts? 40 watts?
    we were running two lights inside the motor home.. the motor home's water pump.. my car's stereo with a 200 to 400 watt sub.. i think... plus the prius's headlights and the motorhomes's running and headlights.. all at different times while i was running my car as a personal a/c system for 7 hours.
  19. hyo silver
    hyo silver Awaaaaay
    15,232
    1,562
    off into the sunset
    OK, that's where I draw the line. A motorhome? That's not camping. :eek: Camping is loading up your bicycle with barely enough for survival, and heading off alone for a destination a thousand miles away. It's setting up your tent in the dark because the next campsite was further than you thought, and at the top of a huge hill. It's eating supper in the dark, too, being thankful you can't see all the mosquitoes cooked into your hamburger. It's...oh, let's just say when the big one hits, I'll know what to do. ;)
  20. Chuck41
    Chuck41 New Member
    38
    Midwest
    Would it be a good idea to include a battery operated carbon monoxide detector in the car if you are going to sleep in it with the engine running?
