A/C and fuel economy.
Discussion in 'Prius c Fuel Economy' started by priusmatty, Aug 25, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Here in Louisiana right now, it gets to about 100 F every day. Obviously, I need the A/C on, or else I will literally die in the car. So, on a long highway, at 55 mph, just to experiment, I turned off the A/C, but left the fan on. My mpg went from about 52, to around 62. Is this normal?
  2. kndy
    kndy Member
    84
    2015 Prius c
    I'll need to try this when it gets cooler because we get around 108-114F here and I need the A/C on but I want to see if my MPG increases after giving it a try.
  3. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    Yes, please do and report it here. Anyone else have any data for A/C versus non-A/C mpg?
  4. Mendel Leisk
    38,726
    We usually turn the vent system off completely, just adjust window opening. The fan just seems to be pumping heat in, defeats the purpose. It's nowhere near your temps here, but it's been regularly over 80F, a lot of the summer.
    The AC definitely impacts mpg, I'd guesstimate between 5 and 10 percent.
    Merkey likes this.
  5. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    That's a huge jump. Wouldn't have expected it.
    After experimenting with AC on/off when I first got the car, I found it did not have a great effect on gas mileage for my normal 40 mile commute, which is half highway and half rural/city. It dropped from an average of 60 mpg to 58 with AC on. I was so thrilled to be getting mileage in that range that a difference of 2 mpg didn't phase me. But at that point (this is my first hybrid) I hadn't learned any of the driving techniques for increasing mileage and was just getting to know the dashboard gauges. Now I get 60 with AC on pretty regularly. But I drive in ECO mode all the time. Was your test with ECO on or off?
    The only time where I saw AC use dramatically effect mileage was when stuck in a traffic jam for 30 minutes in 90 degree weather. The AC runs electrically so normally it doesn't need the ICE to keep it going. But in this jam, going maybe two mph when we were moving, and not moving most of the time, the AC was chewing up battery at a fast pace and the ICE had to keep coming on just to charge the battery to feed the AC use.
    Your difference of 52 to 62 mpg running at 55 mph seems too much, but at 100 degrees, who knows. If that wasn't with ECO on, it would be interesting to see the difference.
  6. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I normally run the A/C with the HVAC system set to "recirculate" on the basis that it doesn't have to work as hard with the pre-cooled interior air as it would with the hot outside air. There's still a small percentage of outside air that enters the system even in "recirc" mode, but it's pretty I haven't done any formal testing, but I've never noticed the A/C sapping my fuel economy.
  7. bisco
    49,488
    no, not normal, but i'm also not sure it's a very scientific study.
  8. Mendel Leisk
    38,726
    We don't use the AC much to speak of through summer. I know, stoics, lol. Mainly just rely on windows. If and when the AC's on, the only time I'd set it to recirc is following a smoky diesel.
    Most of our AC use is in the rain, to keep the windshield clear of fog. If you set mode to Heat/Defog the system will use AC, sometimes, without the AC button being pushed *. I'll try that tactic first, and if it's still fogging, push the AC button expressly.
    * Monitoring the AC compressor wattage, with ScanGauge
  9. priusmatty
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    I always keep Eco on. I may have not notice the numbers as accurately as I should have since I was driving. I will try again when I can really pay attention.
  10. sethr
    sethr Junior Member
    Fairfax, VA
    2016 Prius c
    Although I have had my C just 3 weeks, I had an "original flavor" Prius (2001) for 16 years. The strategy I developed to maximize both comfort and mpg was to always turn off the A/C before pulling away from a stoplight/sign, so as to maximize how far I could get without the ICE coming on. Once the engine came on, I would turn the A/C back on as well. I also frequently waited to do that for a bit longer if it wasn't too hot out. This should work as a strategy with the C as well.
  11. Mendel Leisk
    38,726
    Maybe a PassMaster would work for that, if you can still find them. It's a vacuum switch, open unless your intake manifold has decent vacuum. Under heavy acceleration vacuum drop, switch becomes open. You splice it into compressor power wire.
    It might throw a code tho, with today's cars.
  12. sethr
    sethr Junior Member
    Fairfax, VA
    2016 Prius c
    I'm not that sophisticated - I just manually press the A/C button off and on. Works fine.
  13. Mendel Leisk
    38,726
    Well, ferrying someone around all day, with the AC on more-or-less constant, manage to keep the displayed liters per 100 km at 4.2, where it was at the outset. Still that's on a tank with about 150~200 km since the trip meter was reset. But I'm just not a big fan of AC, still.
  14. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    If my understanding is correct .... the ICE does not power the A/C compressor. From that standpoint, it should make no difference.
    But I agree, there is a fuel efficiency hit when the A/C is on ... and I can only assume the ICE must run more to replace the electricity the compressor use. OTOH, the vehicle is not as "slippery" with the windows open except at very slow speeds.
    Personally .... 100 degrees in humid Louisiana .... I don't care how much it drops the fuel efficiency .... it is worth running the A/C. I lived in Louisiana as a child (before A/C) .... never again without A/C.
  15. booke02
    booke02 Active Member
    391
    415
    Israel
    That is more or less what the air-conditioner ECO mode does. Also, running the drive in ECO mode will also do something similar
  16. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    I have owned and driven a Toyota hybrid since late 2009 ...... and never once driven in anything buy ECO (occasionally EV, but not very often). Am I missing something?
  17. sethr
    sethr Junior Member
    Fairfax, VA
    2016 Prius c
    Correct. But the A/C does use the traction battery, so turning it off before acceleration leaves you more energy available from the battery, allowing you to get to a higher speed before the ICE comes on, thus saving gas.
    As to the functioning of the eco modes equalling the strategy I employed with my 2001 Prius, I have not had the new C long enough to know if that is exactly the same thing or just almost. I would be happy to be enlightened.
    Felt likes this.
  18. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    then this begs the question. if outside temperature is 100° and say temperature inside car is 130° would it be better to not use recirculating until it get cooler inside car then switch on recirculating?
  19. bisco
    49,488
    same. we could be missing an unbelievably exciting experience!:cool:
  20. DKTVAV
    DKTVAV Active Member
    510
    101
    I leave all the doors wide open with A/C on for the first few minutes and then close them back and use recirculating if needed.
    priustexasbob likes this.
