A/C blowing at half speed?
Discussion in 'Prime Main Forum (2017-2022)' started by dlegate, Oct 17, 2018.
  1. dlegate
    dlegate Junior Member
    30
    16
    SF Bay Area
    I've noticed a sudden drop in the pressure / air flow for my A/C & heating system.
    It feels like it's blowing at less than half the power as before, even when I crank the fan speed all the way up. Tried on both recirculate and fresh air modes.
    Are there intake(s) I can check for blockage? Not sure where it is (they are?) located.
    I have only 6k miles on this 2017 Prius Prime.
    Any assistance is appreciated.
    52,354
    check the cabin filter, behind the glovebox, unless they changed it
    is there an eco setting in the hvac menu which might reduce it?
    intake should be the grille below the wipers
  3. dlegate
    30
    16
    SF Bay Area
    So basically the intake is under the windshield (internal or external)? If so, nothing is blocking that at all. Also, nothing blocking behind glovebox either.
    Yes, tried Eco off and back on - no change.
    I think I should probably take it in to have it looked at.
  4. coach81
    coach81 Active Member
    758
    116
    Louisiana
    Yeah sounds like a checkup is needed.
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    You might want to check the Cabin Air Filter/Cleaner behind the glove box. Check YouTube for Prius cabin filter change instructions. They are all basically the same procedure...
  6. FuelMiser
    1,349
    929
    Monument, CO
    There is also a Front Seat/Rear Seat Bias setting that reduces output airflow when the back seat is unoccupied. The button shows airflow to front and an 'x' for the back seat. When the LED in this button is ON, you are not getting full airflow from the upper vents. Also, when in front only mode, it knows whether there is a front passenger and shuts down airflow out the passenger side front vents.
  7. Trollbait
    12,667
    The actual intake is under the plastic valence that is at the base of the windshield. The cabin filter for the old Taurus was under there, and I've found leaves and dirt gathered under there. If that is the problem, that is minor. In my experience with other models, it is the drains that get blocked, which results in rain water on the front passenger floor as the backed up water flows into the HVAC intake.
  8. dlegate
    30
    16
    SF Bay Area
    Thanks for pointing that out... it was already set to Driver Priority, and turning it off/on didn't make much difference.
  9. coach81
    758
    116
    Louisiana
    Please let us know what the problem ends up being...
