A/C blows warm when standing still, fine on the road.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by dboggess3, Jun 28, 2021.
  1. dboggess3
    dboggess3 New Member
    Cartersville, GA
    My A/C has started blowing warm when I slow down or stop.
    It is cold as ice when I am driving.
    The compressor is also making a growling noise.
    Any ideas?
    2012 Prius C One 216,000 miles
  2. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Maybe if you can post a video of the system running, so we can hear the sounds is making and all that. Check if the radiator fan turns on when you turn on the A/C, it should turn on in most of cases, specially if it's hot outside.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes, the basic symptom sounds like the radiator fan may not be running.......or there is some air blockage up there.
    The growling sound likely is a WHOLE different matter.
  4. Mendel Leisk
    42,274
    Guessing there’s two fans behind radiator? Watch them, with the hood up and AC running. If it’s like most systems, both fans should come on, same time as AC compressor.
    growling sound could be AC compressor; any recent AC top up? Dealership or? Speculating recharge with wrong oil.
    paging @lech auto air conditionin
