a/c BUSTED - fair price?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jamielu, May 8, 2008.
  1. jamielu
    jamielu New Member
    houston, tx
    It's not often that I'm blessed with a chance to visit the service dept over at the dealership (thank you prius, you've been so good!!!!!) However, life goes on, things die, and just when summer starts to rear it's glossy head from the clouds...a/c's get busted.
    First time I've had to deal with a major repair like this. SO I can use some perspective on what may be considered a 'fair price'. check it:
    2005 Prius, pkg #5 - 51,000 Miles so far - Warranty is OUT
    Dealer told me the expansion valve needs to be replaced along with the receiver-drier. Labor will included dismantling the entire dash so they can access these components. Dealer is quoting me $1,511 to fix the problem.
    problem is a weak performing a/c. obviously.
    so before I go into shock - is this a fair price? do I have other options? DIY? I'll do it too!!!!:D
    thank ya'll,
    Jamie from Tejas.
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    That's a bit on the steep side, but within range. If you have the knowledge, consider downloading the service manual directly from Toyota and trying it yourself
    I remember when receiver/dryer assemblies were easy to change. With the Prius, you have to get to the evaporator coil, which is really buried in there
  3. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    yep that's what the stealership quoted me too, then i went to where i bought my prius and they fixed it for only 400 bucks! what a steal!
    out of curiosity look deep down from the top and see if your a/c pipe is disconnected? its the lowest pipe hanging from the bottom so a good bump could cause it to go loose from its fitting and spray its r134 refridgrant everywhere!
