A/C Button on Key Fob
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by heather somaini, Aug 1, 2012.
  1. heather somaini
    heather somaini Junior Member
    76
    Los Angeles, California
    I have a PIP Advanced. I've tried using the remote A/C button on my key fob with no luck. Is there some special trick to it?
  2. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    Hold it down for 2 or 3 secs
    51,140
    i think all the a/c controls in the car have to be on.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    THE ATTACHED FILES ARE FROM THE OWNERS MANUAL
    SudeepHArya likes this.
  5. benalexe
    benalexe Member
    198
    30
    Commack, New York
    My dealer said that the a/c button is not really Air Condition but more just swaps the outside air with the inside air. Is that true?
  6. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    How can tell when a dealer isn't telling the truth? When their lips are moving.
    He's confusing that with the solar roof venting which is a nice feature too but not available on the PIP.
  7. chesleyn
    596
    158
    Los Angeles
    He lied. The AC button on the fob turns on the AC while the car doors are shut and the car is off. Obviously it's best to use while the car is plugged in.
  8. CharlesH
    2,796
    1,162
    Roseville, CA
    "Lied" implies telling a deliberate untruth. I suspect that, as suggested by fotomoto, he was unknowingly confusing the A/C button on the PiP with the solar vent fan on other Prius models.
  9. SudeepHArya
    SudeepHArya Junior Member
    46
    Jackson, New Jersey
    2014 Prius Plug-in
    Thanks for the post !!! That helped shave 10 minutes of research time for what that button did!
  10. GregP507
    GregP507 Senior Member
    3,002
    481
    Perhaps the temperature setting control has to be lower than the interior temperature, and I think it has to be turned on before you shut off the car.
  11. CharlesH
    2,796
    1,162
    Roseville, CA
    From discussions a couple of years ago, I recall that the temperature setting has to be lower than the interior temperature, and there has to be some reasonable amount of charge in the traction battery to power the A/C compressor. I don't recall anything about it having to be turned on before you shut off the car, but I could be mistaken. I have never used that feature. I think it works the same way for the smartphone climate control app on the Advanced. With the key fob, you need to be within its range, but the smartphone app works from anywhere. I DO know that it is designed so that it will never cause the ICE to turn on.
  12. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    What is the practical use on a Basic? If you need to be within key fob range, you are about to open the door anyway, which will turn it off
  13. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yup, completely useless unless you are parked right outside your house or office desk within range to start it up before you walk out the door. I never use it.
    iPhone ?
  14. GregP507
    3,002
    481
    Sounds like a good accessory to add to my Compustar remote.
    It has a 6000ft range.
  15. Barbara R
    Barbara R Junior Member
    44
    2014 Prius Plug-in
    Which model Compustar do you have? Do you mind saying where you got it and how much it cost?
  16. GregP507
    3,002
    481
    This is the one I have: PRO 2-WAY 901 | RF-P2W901-SS | Remote Starters
    I don't know the cost because the dealer included it in the deal, and installed it at no charge. They told me it was a $900 value, but I really don't know the price. I've seen them online, priced anywhere from $250-$750.
    I'm quite happy with mine; the only negatives are that is can be quite complicated to use in advanced modes, and the internal battery needs recharging fairly often.
