A/C compressor oil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drive2much, May 16, 2011.
  1. drive2much
    drive2much Junior Member
    42
    Denver
    Is there a way to verify whether the proper A/C compressor oil was used?
  2. Patrick Wong
    18,200
    6,492
    It's hard to say whether the right compressor oil was used, but if your car logs a hybrid vehicle ECU DTC which shows a high voltage ground fault with the AC compressor then you'll have evidence that the wrong compressor oil was used.
