A/C compressor only works while braking from highway speed
Discussion in 'Gen 4 Prius Main Forum' started by Greg Power, Jul 7, 2023.
  1. Greg Power
    Greg Power New Member
    Rocklin
    Three Touring
    Air conditioning only blows cold while coming to a stop from 65+ mph. Recently took it to the dealership where they checked for leaks and pressure and came out with nothing. Where should I start?
  2. JC91006
    16,493
    8,403
    Has the refrigerant ever been refilled? How much did the dealer charge to tell you nothing is wrong?
  3. Greg Power
    Rocklin
    Three Touring
    It hasn’t to my knowledge been refilled. I had one shop look at it for over an hour and didn’t charge me a penny because they couldn’t find the issue. The Toyota stealership in Roseville charged me $209 to tell me it works fine.
  4. JC91006
    16,493
    8,403
    On the 3rd generation prius, if you have the car on ECO mode (not sure that's on 4th gen), the AC will not blow very cold. If you have that setting and using that setting, maybe you should try the normal setting.
    If the problem still comes back, bring it back to the dealership. You don't have to accept the original Tech's diagnosis, ask for the shop foreman to make a better diagnosis. You did pay for it.....
  5. Greg Power
    Rocklin
    Three Touring
    Finally fixed, here’s what they found;
