A/C condenser replacement
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Lildevil, Jun 7, 2023.
  1. Lildevil
    Lildevil Junior Member
    30
    Omaha, NE
    Has anyone replaced the a/c condenser on a 2012 Prius V and is there a video for it? I can buy a new condenser for @ $210 and prefer not to spend $1187 at the dealership to do it.
  2. rjparker
    rjparker Tu Humilde Sirviente
    8,102
    4,805
    Texas Hill Country
    Have not done it personally but from what I have seen the inverter radiator and the condenser come out together after removing the bumper cover, hood latch support assembly, hoses, fan shroud and pipes. Then the inverter radiator and built in condenser dryer are removed. The old condenser will have oil in it so the new one has oil added along with a new dryer. I would have a pro evacuate and charge.
  3. Lildevil
    30
    Omaha, NE
    Thank you!
  4. ivanhoe
    ivanhoe Member
    66
    26
    2015 Prius v wagon
    I wouldn't buy a aftermarket one, mine was replaced with one through the insurance and only lasted two years! It corroded and was driven sparingly during the winter.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,529
    1,611
    NJ-USA
    If you do replace the condenser yourself, you need to have the system properly evacuated and recharged with new refrigerant and the correct oil.
    ivanhoe likes this.
