A/C constantly switches from "Fresh" to "Recirculate" Grrrr :(
Discussion in 'Gen 2 Prius Main Forum' started by uart, Oct 20, 2009.
  1. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Firstly let me say that the weather is mild to warm here this time of the year and under these condition I often prefer to have the A/C off and just the fan blowing in fresh air.
    Ok after a bit of fiddling on the MFD I can make it do this, so far so good, but after I've stopped and re-started the car however the unit seems to remember all the other settings (fan comes on with A/C off) but it always resets back to recirculate. It's really getting annoying, I stop for 5 minutes at the shop and get back underway then start to notice the car is getting a bit hot and stuffy. Oh yeah that's right its back on recirculate and I've got to frig around with the MFD to set it back to "fresh" again.:mad: I'm doing it 5 or more times a day but in reality I'll want it to stay on fresh for the next month or more.
    Is this the case for all 2004/2005 gen-2 Priuses or is mine kooky or is there a setting that I haven't figured out yet to make it remember this setting.
  2. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    Turn off "auto a/c" and it will keep your settings.
  3. patsparks
    10,664
    567
    Adelaide South Australia
    There is a button on the right side of the steering wheel to toggle between recirculate and fresh air. It is the top half circle button.
    I agree it is a pain but I haven't found a work around apart from pressing the recirculate button. I have no idea why it does this. I'm like you, I like to just have the fan on fresh when it's warm. I like to keep the vents on fresh all the time unless there is a bad smell coming in or I am about to drive through a dust cloud.
    I don't know why Toyota set it up like this, but I have learnt to live with it.
  4. patsparks
    10,664
    567
    No it doesn't. I have the same problem.
  5. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Thanks Pat for confirming that this really is a bug in the climate control logic. The tip about the button on the steering wheel will certainly help the situation (save me from fumbling about with the MFD every time I start the car). :)
    This is my take on why Toyota choose to implement it the way they did. If you're actually using the climate control (for either heat or cool) then it's obviously inefficient to always use fresh instead of recirculate. So effectively the computer is saying "naughty naughty - that's a bad inefficient setting that you've chosen, ok I'll let you do it for now but then I'll override you later when you're not paying attention".
    The problem is they completely failed to take into account that it's not at all inefficient to use "fresh" when the outside air temperature is already perfectly comfortable and you're neither trying to heat or cool it.
