A/C died mid road trip in 98 degree Bakersfield...
Discussion in 'Gen 2 Prius Main Forum' started by ewxlt66, Aug 10, 2013.
  1. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Started blowing warm coming down the grapevine headed north to big Sequoia land.
    We tried to tough it out, but with the 1 and 4 year old in the back, we had to stop.
    Yelped the nearest dealership and found Bill Wright Toyota.
    They got us in right away. 2 hours later, the freon was charged, a hose reconnected and a/c was blowing cold. Oh, and they washed it.
    $189 later, we were on the road and finished the road trip.
    43mpg on the way up.
    56mpg for the way home.
    Not bad for a 2008 Gen II with 1114k miles loaded with 4 people and luggage.
  2. jgilliam1955
    368
    102
    Williamsburg, Virginia
    Great service and trip.
    SCH-I535 ? 2
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    Hmm, might seem moot but I'd check circulation in inverter coolant tank, no ac is a sign of it's failure, just sayin..
    51,155
    that's pretty decent for a dealer who had you by the culiones!:p glad it worked out, i can picture my kids in the back seat in that temp, not a good thing!
  5. emsee
    emsee New Member
    22
    DFW, Texas
    Came in expecting a horror story. So glad it worked out for you and your family!
  6. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    A million miles or too many 1's?
    caymandiver75 likes this.
  7. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    That seems like a great price. I called my local dealer (Renton, WA) and was quoted $250 for a simple recharge.
    Does anyone have any Seattle area recommendations for inexpensive, Prius qualified, AC work? The AC is functioning but it isn't blowing super cold. It's good enough for the Seattle area where we don't get very warm, but it seems like it should be blowing colder.
  8. lech auto air conditionin
    830
    601
    261
    san francisco
    I know $250 sounds high but what a Pruis owner or any electric car owner or even most auto shop owners do not know. The qualified competent shop owner and TECH will have to purchase a second dedicated A/C recharging machine just for hybrids, a cheap one at about $3800. and a good one at $6800. on top of that they will have to purchase a refrigerant identifier for around another $1200. top grade hybrid only trace dye and the different electric compressor oils for the different compressor manufactures. All this for a shop that will only see a small fraction of this type of electric or hybrid car as part of their yearly business. The majority of shops are not doing this and the customers are getting the cheaper price at first but paying a higher price in the long run and they do not even know it. Wait until you see the price of the new refrigerant that the shops will have to buy another new refrigerant A/C machine for and all new oils for both the electric compressors and new oils for the conventional compressors, YES I did say oilS more then one type being added to the already long list.
  9. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    ... I would've just went to an auto parts store and got some EZ charge 134. AlsoI'd suggest having the A/C on recirc. anytime it's 90+ out. It's much easier for it to keep cool air cool than to make hot air cool.
  10. FreydNot
    FreydNot Member
    216
    37
    Seattle, WA USA
    I was under the impression this was a bad idea because standard oils would damage the HV exposed compressor.
  11. rocketrob
    rocketrob Member
    104
    Los Angeles
    That's a lot of miles! o_O
    Grapevine is a car killer, it's certainly the toughest stretch of freeway I've ever encountered and the shoulders are always littered by cars with flashing hazard lights.
    I just drove the Grapevine (Southbound) this Sunday evening. The Prius impresses me with it's ability to keep up speed on steep inclines without taxing the ICE too much (<4,000 rpm), presumably due to good torque from the electric motor.
    Prius also handles long downhill grades with ease, applying a good amount of deceleration from regen braking without need for physical brakes. When the SOC gets to ~80%, then regen brakes still decelerate but energy is shunted.
    I wonder though, do long periods of regen braking cause the transaxle to get dangerously hot? I don't think ScanGuage has an inverter coolant temp gauge (??).
    Anyway, sorry to hear about your A/C. Glad you had a good service experience.
  12. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Regen braking will make for transaxle heat. At what point the temp gets to be dangerous is an open question. Toyota specs allow temps up to 110C before error codes are stored, which is much hotter than I would ever want to see. Going down a long hill will eventually fill the batteries up to all green bars. At that point the engine braking will come on (B mode) which will absorb the energy that can no longer go to the batteries. That will happen before the transaxle gets too hot, as the batteries don't have all that much capacity. If on the long coasts downhill you don't hear your engine starting to rev higher (going into B mode) then you are not regenerating all that much and temps are going to be OK, which for my preferences is less than 70C.
  13. rocketrob
    rocketrob Member
    104
    Los Angeles
    Is this right? In my experience when batteries reach full SOC the engine never switches to B-mode and the effect of regen braking is still felt. I think that when batteries are full, the extra energy is simply shunted instead of being used for charging.
    Plus, I personally don't like using B-mode on long downhill grades since it induces considerably high rpms (wear & tear) and doesn't provide very much deceleration. Sometimes, for short periods, I'll shift into N and use normal friction brakes. Clean off the rotors!
  14. nh7o
    1,686
    340
    Hawaii
    Shunted by what? Shunting implies energy dissipation, and there is no big resistor bank to perform that role. It is the engine which is spun to do that. On the slow and steep mountains here the car goes into B mode all the time. Yes, the deceleration in B is not so much, and the friction brakes work harder then. In fact the biggest disadvantage to the Prius for my uses is in going down long twisting descents. I am sure I won't see the brake pad life that others report.
    I think most people don't see B mode because their roads are fast and not so steep.
  15. ewxlt66
    535
    186
    Dana Point, CA
    Wools! Meant 114k!
