A/C is only blowing hot air
Discussion in 'Gen 2 Prius Technical Discussion' started by exito3, Aug 17, 2007.
  1. exito3
    exito3 New Member
    Help!!! My 2004 Prius A/C suddenly started blowing hot air. I started my Prius as always; nothing fancy, so I don't know what happened. I checked every posible misplace on the climate screen, but everything looked normal. What can it be??? A fuse? a programing malfuntion? I need some help....
  2. 1fixitman
    1fixitman Member
    182
    Augusta, GA
    <div class='quotetop'>QUOTE(exito3 @ Aug 17 2007, 08:54 AM) [snapback]497749[/snapback]</div>
    How long has it been since you checked your cabin air filter? Sometimes rocks and road hazzard material kicks up and punches a hole in the A/C compressor/line. Check that also. Set the system to max low temp setting and see if it gets cold. You need to tell us how many miles are on your vehicle as that helps diagnose the problem. Also....This thread is for tech discussions. The maintenance and troubleshooting area is where this thread should have originated.
  3. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    <div class='quotetop'>QUOTE(exito3 @ Aug 17 2007, 07:54 AM) [snapback]497749[/snapback]</div>
    You might also want to read the discussions in these threads.
    Hot Air Problems
    http://priuschat.com/index.php?s=&show...st&p=487769
    http://priuschat.com/index.php?s=&show...st&p=445319
    General Thread on A/C in the Prius
    http://priuschat.com/index.php?s=&show...st&p=382375
  4. exito3
    exito3 New Member
    <div class='quotetop'>QUOTE(D Rock @ Aug 17 2007, 08:24 AM) [snapback]497761[/snapback]</div>
    Soory it's my first time here...My 2004 has 30000,I checked the cabin air filter and had it cleaned a little to see if it was the filter, but still was blowing hot air...I don't know where to check the a/c line/compressor. I aslo checked the 10a fuse... any thing else you may help me? THANKS
