A/C issues - intermittent Red Triangle + Radiator icon
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marigold2, Jul 23, 2025 at 10:37 PM.
Tags:
  1. Marigold2
    Marigold2 Junior Member
    Wisconsin
    My 2009 Prius (337,787 miles) has been having an issue with the red triangle + coolant icon coming on and going off intermittently since 2023. Every time I get it fixed, the issue it comes back within a few days to weeks. I am looking to see if anyone might have some thoughts on what could be causing the issue and maybe a fix.
    I no longer have a catalytic converter, so I do get the O2 sensor code periodically and the check engine light comes on and stays until I replace the gas cap.
    So far, my poor car has spent 6 months and $4k at the dealer, then quality time in the garage when I had no funds to try again...as the dealer indicated they would need more $$ to continue.
    Then I decide to try a local mechanic who has tried his best to fix things - basically rebuilt the whole main engine A/C system as it seems the main A/C system was full of sludge - best guess is the dealer put stop leak or something in it to "fix" the code problem - and I had no air conditioning or heat.
    I picked it up and started to drive it home and got lights again. He replaced a couple more parts and basically kept testing it until he didn't get any lights. 3 weeks later I picked it up and brought it home. Took it out for a grocery run and on the return trip home I got the red triangle + coolant icon and no more cold air.
    I have had the following done thus far:
    At the dealer - over a period of 6 months for codes:
    P1150
    P1121
    P1151
    P1116
    P0117
    Replaced Radiator (16041-21281)
    Replaced Condenser (88460-AZ010)
    Replaced Radiator temperature switch (8947-47010)
    Replaced housing connector (90980-11235)
    Repaired terminal (82998-12440)
    Replaced Coolant Flow valve Water Valve Assy, Water (16670-21010)
    Replaced coolant heat storage tank (16660-21011)
    Local mechanic codes and replaced the following -
    P1116
    P1121
    Replaced Air Door actuator
    Replaced Heater Core
    Replaced Evaporator Core
    New Antifreeze/Coolant
    Fresh Refrigerant
    Replaced Auxiliary Heater tank
    Replaced the thermostat and housing (as the housing was in bad shape)
    Replaced the coolant temperature sensor
    Bled both A/C systems (engine & hybrid) to get all the air bubbles out.
    And I now have code P1116 again, and no cold air.
    At this point I may have to sell it as it doesn't seem to want to be fixed. Which I really don't want to as this car has been the best car I've had until this point. I bought it new.
    Please note - the alarm lights are intermittent, they stay on a bit and then go away. Sometimes they do not come on at all, sometimes they go off and on during a trip, sometimes they actually stay on and I can get a reading of the codes. The codes tend to disappear, and the dealer began to think I was crazy. I bought a Blue Driver scanner so I could run a scan while driving to show the dealer that the codes were occurring...as well as video. I have yet to find any pattern with the alarms...no combination trigger. It's very frustrating.
    I am hoping someone else has had a similar issue and actually got it fixed so it worked. Or maybe there's a Toyota mechanic who has a suggestion.
  2. Tombukt2
    Tombukt2 Senior Member
    12,287
    2,165
    Durham NC
    Good gawd I was looking this to be Middle East or such . But right here in USA . You could a bought two Southern cars in perfect condition for all that work done to a car in a rust state to boot . Wow.. serious game here . Sounds like parts howitzer still firing . I'm so sorry for you're losses . Must be the winters or something.
  3. Hayslayer
    Hayslayer Member
    225
    117
    Apparently shooting the parts cannon at it hasn't worked. There's a more than a handful of coolant hoses connecting the engine, flow control valve and storage tank. One of the first things I would do is to make certain they are all routed and connected correctly.
