A/C not working, makes grinding noise when turning on A/C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Gudnidy, Jul 22, 2015.
  1. Gudnidy
    Gudnidy New Member
    Fresno, CA
    Fearing the worse here on my 2011 Prius Four, not IV. When I press the "on" A/C button I hear a grinding noise for about two seconds. Seems to be coming from a low area in engine.
    Any suggestions? I wish I knew how to upload a video to this thread.
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    the ac compressor is the most likely suspect...
  3. JC91006
    16,482
    8,400
    upload to youtube and provide a link
  4. Gudnidy
    Gudnidy New Member
    Fresno, CA
    Thanks. Here's the thread
  5. JC91006
    16,482
    8,400
    this sound happens every time the AC turns on? I actually didn't hear the AC come on. Is your engine low on oil or does it burn oil? Sounds like an engine trying to turn over
  6. Gudnidy
    Gudnidy New Member
    Fresno, CA
    Maybe its louder than normal. Not sure. I've had the car over a year now and never noticed the noise. Oil good. The A/C is blowing hot.
  7. JC91006
    16,482
    8,400
    Well your issue is not that it makes the noise....your issue is the AC DOES NOT WORK :D
    Well somebody with more knowledge will need to help you. Sounds bad I must say
  8. Gudnidy
    Gudnidy New Member
    Fresno, CA
    Here's a longer video with the grinding getting worse. Car engine is fully charged and quiet. All the noise you hear is when the AC is turned on. Painful to listen.
  9. Gudnidy
    Gudnidy New Member
    Fresno, CA
    Appreciate the time. Thanks.
  10. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    I think this might be in the wrong subforum, since it's listed under Prius C.
  11. Gudnidy
    Gudnidy New Member
    Fresno, CA
    Thanks. I'm lost with this stuff. Lol.
    PriusC_Commuter likes this.
  12. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    Thought so lol. You will likely get better traction in the right subforum. A mod could move the thread for you.
  13. bisco
    49,500
    take it to a dealer, get a repair estimate, and call toyota for a good faith warranty.
  14. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Even without the ICE running, when I turn on the A/C/Auto (outside temp 90º+, cabin temp set to 68º) I can hear creaks and groans of the flaps/servos being moved, as well as the recirculating flap being moved (although as the target temp is reached the recirc. flap is returned to its normal (external) position. - hope this helps - Wil
  15. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    My GII has developed a recirculating damper noise too.
    I am beginning to think about what it will take to fix it.
  16. WilDavis
    2,492
    2,153
    49
    Ear-plugs? …or turn up the stereo? ;)
