A/C On Button
Discussion in 'Prime Main Forum (2017-2022)' started by Kan, Apr 30, 2024.
  1. Kan
    Kan Junior Member
    35
    Las Vegas
    2022 Prius Prime
    Please excuse my lack of know how, but it's a learning curve! My car has the 11.6" multifunction display and the only way I know how to turn the A/C on is by using the far speed button, and I turn the A/C off by pushing the Off button on the display. If I use the AUTO button to turn air on, it usually come on at the highest speed which I don't like, because that requires further dialing down with fan speed button to a lower air setting. Is there another button to turn A/C on that I'm not seeing? Thanks.
  2. schja01
    schja01 One of very few in Chicagoland
    1,746
    1,162
    Chicagoland
    2018 Prius
    I leave the system on AUTO. If I set the target temp below the current temp the A/C comes on. The further I set the target temp from the current temp the faster the fan runs. I don't think I've ever overtly turned the A/C on or off. It just goes on and off depending on the current temp and target temp.
