A.C. operation while the car is parked.
Discussion in 'Prius v Technical Discussion' started by Ronald Doles, Aug 31, 2020.
  1. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    I posted this in another thread and probably should have started a new one here. It is just observation of how the Prius A.C. behaves while parked. I thought that it was interesting. Actually, I think I bought this car as a science project.
    I dropped off a fellow vet who needed a ride for testing at a VA clinic last week. It was 92 degrees and due to covid they wouldn't allow people to sit in the waiting room / lobby so I along with many other drivers parked in the shade on a lower level of the parking deck to wait for our patients.
    I had the A.C. temperature set to 74 degrees and had a few hours to observe vehicle operations by selecting various parameters on my ScanGauge.
    When I first got back in the car and pressed Start it initially drew about 8 amps. Traction battery current gradually dropped as the car cooled down and it stabilized at about 3 amps. The circulation fan ramped up to about 4 or 5 bars and it gradually dropped back to one bar as the car reached the 74 degree setpoint.
    After the initial 10 minute cooldown, the ICE would run for about 2 minutes and then switch off for about 12 minutes. I began monitoring "SOC", state of charge of the battery and SOC would gradually drop. The ICE would start each time the SOC dropped below 40% . The ICE would switch back off when the SOC rose above 50%. Traction battery charging current was 20-25 amps.
    I was trying to visualize what was going on. Correct me if I am wrong but with the ICE off, energy would be consumed by electronics, the A.C. compressor motor, the circulation fan motor, and a radiator condenser fan motor.
    With the ICE running, energy would be consumed by electronics, the A.C. compressor, the circulation fan, the radiator condenser fan, the inverter coolant pump, ICE cooling pump and a second radiator fan.
    I am not sure about the operation of the traction battery cooling fan. Once Start has been pressed does it run continuously probably at a low speed? I would expect that the fan speed is probably dependent on sensors on the traction battery. Or is the fan off until sensors on the traction battery call for cooling?
    Is the 20-25 amp charge the actual generator current? Is the actual current going to the battery less than that in order to power those pumps and fans?
    This was the first time that I had a reason to just sit in the car parked with the vehicle started for any length of time. It seemed very efficient to me considering I was sitting next to a Tahoe whose engine idled for hours and I could hear the distinctive click of the Tahoe's air conditioning clutch engaging and disengaging over and over.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    Personally I would prefer this mode would charge the battery further and then let the battery run the ac longer every cycle. Often the current algorithm will leave the soc low when full driving resumes.
    During the charge cycle, most vehicle current would come from the motor generator through the inverter converter power conditioning. Any charging operation depends on a higher voltage from the charging source in order to force amps into the battery. Since the dc buss is then at a higher voltage, the source of the increased emf becomes the primary source for all loads, especially when the source has the capacity to run all loads and still keep the dc buss higher than the nominal battery voltage.
  3. ChapmanF
    17,349
    The radiator and condenser are stacked one behind the other, and behind both of them are two fans. For some sort of hysterical reasons, one is called the 'condenser' fan and one is called the 'radiator' fan, but they are wired and controlled together, either on low or high speed. Several conditions from the engine and A/C controls are OR-ed together to determine when the fans run, and low speed or high.
    The engine power goes into the transaxle. Power to the wheels comes out of the transaxle, and it also has an electrical connection. When more power is going to the wheels than the engine is producing, the electrical power flow is into the transaxle. When there is a surplus, the electrical power flow is out of the transaxle.
    If your 'current' reading comes from the battery current PID for the ScanGauge, that is measured by a donut right back at the battery, so it is the current out of or (into) the battery itself.
    There is also an AC Watts PID you could use to monitor the power being used specifically by the compressor.
    Tim Jones likes this.
  4. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    I have to agree, what would it hurt to charge to 70% SOC? ICE duty cycle would then be something like 6 minutes on and 36 minutes off.
    Thanks for the info. I don't know that I will be in a situation like that again but I will look into adding the Watts PID Xgauge to my ScanGauge.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,042
    775
    Virginia, USA
    As a Prius camper, I wholeheartedly endorse your preference, albeit for very different reasons.
  6. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    Before I retired I worked in several Japanese transplant automotive plants. Their engineers are sooooo conservative, agonize over decisions, want to do some things in the most obtuse way and change their mind at the last minute. It may explain why things work the way our cars work the way they do.
    I spent 3 months at Toyota Georgetown commissioning an e-coat paint line that we were commissioned to design and build. The project consisted of a body wash, basically a glorified car wash, an e-coat primer dip tank and a drying oven. Japanese automotives were tough to work for and Toyota may have been the worst . It is an extremely frustrating environment to build automation. You think that you have the drawings done and approved or you think that you have the code finished per the specs that they provided and then at the last minute things change. Their specs probably came from Japan and then one of their engineers on-site will decide that is not how he wants his system to work.
    Case in point. The RFQ (request for quote) listed approved PLC's (programmable logic controller) for the Georgetown project. Alllen Bradley was on the list which made it easy for us. They are probably the most popular brand in the U.S. and we use a lot of Allen Bradley. We created the electrical controls package for the project using Allen Bradley PLC's and equipment. We took two months coordinating with their engineers and it took several hundred hours to creae a 30 page set of electrical drawings. I had made a good start on the three controls programs. We sent the drawing set to Georgetown for final approval. They came back approved as noted. I flipped through all the pages and there were few mark-ups until I got to the last page. On it were the instructions "Use Toyopuc".
    I called to inquire about this comment. One of their engineers had changed his mind. This is when I learned that Toyota actually makes their own PLC. I had never heard of it and asked where I might find a distributor for it. Unlike Allen Bradley who can be purchased from electrical distributors in cities across the country, there is one distributor forToyopuc in the U.S. and it was in Chicago. We had to revise our electrical drawings, back to the drawing board literally, to reflect the substitution of a Toyopuc control system. My programming time was wasted. I called the distributor in Chicago to order the equipment. I told the distributor that I wanted 2 programming terminals, 3 PLC's, 48 of the 120 vac input cards and 35 of the 120 vac output cards and all the cables etc.
    He took my order and then a few days later he called to ask me if I knew that their 120 vac output cards were not U.L. approved. I told him that I had scant information on anything Toyopuc and that I would have to call Georgetown as surely they must already know. The engineer at Georgetown replied "well then you can't use them then" .
    He suggested that I switch all my output devices to 24 vdc. I explained that much of the equipment had already been ordered as 120 vac from vendors like Honeywell because of the long lead times in order to meet their timeline. He then suggested that I replace the 120vac output cards with 24 vdc output cards which are U.L. approved and then use a relay on each output to control the 120 vac devices. I ended up having to redo the drawings a third time including enlarging the control enclosures to accommodate nearly 300 ice cube relays.
    On another note:The other electrical engineer from my company was approached by a Japanese engineer to inform him about a water leak on a pump motor. He replied that he did not do plumbing, he was electrical but he would find a pipe fitter to look at it. The Japanese engineer was offended and replied you work for "XYZ" everything on this project is your responsibility. He complained about my colleague to our general manager and he was removed from the job. My company sent a replacement but that didn't know anything about the job so I was pretty much on my own for the next couple of weeks. As if working 70 hours a week wasn't enough lets make it harder.
    I liked working in Honda plants as there was more cooperation and fewer surprises.
    I was so happy when that project was done.
  7. ChapmanF
    17,349
    Sounds like we've had similar gigs doing similar kinds of consulting. A firm where I worked also had a lot of automotive work. The differences were interesting.
    The Ford plants where we worked had comfortable labor-management relations, and were comfortable for us.
    The GM plants had very strained relations, it was like walking into a family reunion including the uncle your mom hates, and the line guys regarded outside contractors like us more or less as scabs and would hide our tools and stuff.
    We had a job at a Nippon Denso plant. Any surface in that plant, you could eat from. Labor and management all wore basically the same simple uniform, I think you could tell management maybe by the color of their caps. We tended to show up on site in Midwest America Casual and were kind of vaguely disliked. At one point I suggested we buy some shirts that matched and get embroidered name patches, and we were noticeably better liked after that.
    Johnny Cakes likes this.
  8. rjparker
    9,597
    5,894
    Texas Hill Country
    Did not know Toyota did transplants.
    In any case, my experience suggests some specifying engineers are amazing and some are green. Same goes for the contracting engineers. Its often the luck of the draw. Its the relationship between front line guys that make the difference. I spent years on both sides of the fence, first as a contractor and second as the specification and commissioning guy. A green engineer in either job gums up the works.
    In the end its the results that matter. On the customer side, does it functionally and reliably work. On the contractor side, did we satisfy the needs and still make money without burning bridges.
    When it comes to Toyota implementing their quality standards in North America, I say more power to them. I know the truck plant near me in San Antonio still produces quality as does the Mexican Tacoma factory and the Canadian hybrid plant. Left to their own devices, those plants would likely build to a much lower common denominator.
  9. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    In 1990, Honda announced a new manufacturing plant would be built in East Liberty, Oh. We received a $45 million order for the paint shop mechanicals. The lion's share of that was to design and build the paint booths and drying ovens but about $5 million dollars was for electrical equipment. There were 260 fan and pump motors up from 1/2 hp up to 250 hp, 100 Honeywell single loop temperature controllers and Honeywell control motors, Mitsubishi PLC hardware and Westinghouse easy-starts for motors over 200 hp. I was going to have to write 24 control programs for the 13 paint booths, 10 drying ovens and a sludge treatment plant. The PLC's would all be networked together and linked to their Central Control Room. At the peak of construction there were 165 electricians out of the union hall in Columbus running pipe, pulling wire and making terminations. Sprinkle in a bunch of pipe fitters running water and gas lines and it was like an ant hill.
    After about 8 months of construction we got to the point that we could begin to power up the first of our control panels, the Honda's paint shop manager had instructed his maintenance associates to shadow us and learn how the equipment worked. I would be stooped over a terminal making some program change and when I stood up I bumped into an associate that had been looking over my shoulder. I would reach for a start button and an associate who was observing would beat me to it. By the time we had the programs in all the ovens and booths the associates had the equipment running when we got there in the morning. They had taken over and were making their own adjustments on limit switches, temperatures, pressures etc. The associates had a morning meeting and after that meeting, their team leader would give me feedback on items that they would like to have work a little differently. I felt good walking away from that project.
    When we did the Georgetown project, the Toyota associates sat in their break room. The first time we fired up the drying oven there was oil smoke burning off of some of the panels and rising in the bay. One of the associate called me from the break room and asked if I could have someone turn on the overhead exhaust fans. In the time it took him to get me on the radio he could have walked the 50 yards to the switch and done it himself. When we were ready to turn the project over, the associates questioned who was going to train them on the equipment.
    Just a difference in philosophy.
  10. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    I didn't mean to imply that Toyota was the worst automotive to work for. It was just that project. We experienced more problems at any of the big three plants for projects that we had there than Toyota, Honda, Mazda or Nissan.
    Typical was one GM install. I signed in and was waiting at the gate for an employee to escort me to their casting department. I was going to install a ladle (robot) that dipped molten aluminum from a furnace and poured it into a die-cast machine. When the employee arrived, the first thing he said was "You aren't taking that tool box into the plant". I always had a small startup toolbox with my meter, hand tools, tape, labels, wire ties etc. I took the toolbox back to my car.
    I got to the ladle and began the checkout of the connections to their die cast machine. I found two wires that needed swapped. I had to find the area supervisor and requested an electrician. He got on his radio and about 15 minutes later an electrician arrived in an electric cart. He swapped the two wires and left again. A few minutes later I discovered another pair of wires that were reversed. I tracked down the supervisor and explained that we had quoted 3 days of startup time to commission the ladle but without tools and with a roving electrician it would probably take more like 3 weeks. The supervisor called and requested that an electrician be assigned to assist me.
    My electrician arrived but after about a half hour, he said he had to see someone and he would leave his tool belt there and he would be back later. He said if anyone questioned me about using tool to explain that he was covering me and it was OK. I didn't see him the rest of the morning but since I had his hand tools I was fine. Union shops just added another layer of difficulty to start-ups.
  11. Ronald Doles
    230
    280
    Columbus, OH
    2015 Prius v wagon
    To add to my observations of the PriusV while in Ready mode and sitting. I was waiting for my wife at the Post Office today and seeing the parking lot was full, knew she had a wait ahead of her. I decided to observe how the engine cycles on and off in colder weather to keep the engine temperature up to provide cabin heat.
    It was an indicated 38 degrees out and the console temperature setpoint was 72 degrees.
    While driving the ICE coolant temperature reached 105 degrees and the console indicated that the interior fan switched on at one bar. At 110 degrees the fan speed increased to 2 bars and 115 degrees increased it to 3 bars. The temperature eventually reached 160 degrees and I noticed that the the console fan speed display showed four bars. As the cabin warmed up the fan indicator dropped to three bars and then to two bars.
    While sitting in park the ICE switched off and the coolant began cooling off. With the fan at two bars, the ICE switched back on when the coolant temperature dropped below 115 degrees and it switched the ICE back off when the coolant temperature exceeded 130 degrees (15 degree span).
    As the cabin approached 72 degrees the console fan display dropped to one bar. At one bar, the ICE switched on at 110 degrees and off at 125 degrees. Still a 15 degree span but with the lower range.
    With the 38 degree ambient, the ICE ran about 3 minutes on and 3 minutes off in either case.
    While the engine was running I switched the ScanGauge to display Gallons per Hour and the engine was consuming fuel at a rate of .4 gph so with the 50% duty cycle it would consume about .2 gph. Lower ambient temperatures would force the engine to consume more to maintain the cabin temperature but .2 gph, less than a quart of fuel, at 38 degrees is pretty remarkable.
    I marvel at all the scenarios that the engineers worked through to get to this final product.
