A/C recharge
Discussion in 'Newbie Forum' started by carcarcar123, Aug 27, 2018.
Tags:
  1. carcarcar123
    carcarcar123 New Member
    asheville NC
    I have a question about A/C recharge. I really want to do it myself, and I know that there are specific requirements about the type of refrigerant/oil used.
    Can I just add Interdynamics Certified A/C Pro Refrigerant 134a for hybrid vehicles?
    Or do I also need to add FJC 9148 Oil Charge (for hybrids)?
    I've only ever done the all-in-one charges on other vehicles, and I don't really understand- When do I need oil? Do I only need oil and not refrigerant?
    Which one do I add first? Do i need to drain it first?
    PriusCamper likes this.
    49,511
    welcome.
    report your post and ask that it be moved to the gen 2 maintenance and troubleshooting forum, where more expert eyeballs will see it.
    all the best.
    RCO likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,231
    5,934
    Columbia, SC
    If your system slowly degraded due to a small refrigerant leak, there is no need to add oil. All you need to do is purchase a bottle of R134a (no oil, no leak stop, no leak detection dye). One of those single use setups from AutoZone, etc would work just fine.
    Oil in a refrigerant system is rarely ever lost due to a slow leak. Only refrigerant is lost. A fast leak on the other hand, will entrain oil as it violently exits the system through a failed component.
    What you don't want to do is create a situation where you have excess oil in the system.
    RCO and ITBland like this.
  4. Mendel Leisk
    38,739
    Attached is an excerpt from Repair Manual, the AC info.
    Personally? I'd just head for a dealership, prepared to spend about $150.
    • AC.pdf
      File size:
      3.1 MB
