A/C refill with a refill kit?
Discussion in 'Gen 2 Prius Technical Discussion' started by nusskiller, Sep 18, 2014.
  1. nusskiller
    nusskiller Junior Member
    Sacramento, CA
    Hi @all,
    I just want to know if there is a special A/C refill kit available for the Prius. I read somewhere that the electric driven compressor needs a different refrigerant than a regular a/c - I am a little bit confused. I found this on amazon:
    But it seems to be oil for the compressor but not the refrigerant itself. Can I simply refill the system with standard R-134a refrigerant?
    Thanks in advance!
    Steven
  2. vskid3
    vskid3 Active Member
    773
    228
    What makes you think it needs a refill?
    The AC is one system in the Prius that I would let the dealer deal with.
    49,374
    concur.^
  4. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    The Prius uses the same R134A refrigerant that all other cars use, but the lubricant is ND11, which is for electrically driven compressors that need better high voltage insulation. ND11 is not compatible with other oils. The pro shops need to have separate equipment for ND11 to avoid cross contamination.
    The need to top up the system implies a leak, so that is best fixed first. Unlike the conventional belt driven compressors, the Prius system is hermetically sealed and won't leak unless there is damage. I would second the above advice and leave it to the pro's.
  5. Fred_H
    Fred_H Misoversimplifier
    546
    473
    26
    Germany
    Hi Steven, below is my response to a similar question from this thread: Recharging my A/C?
    Also click on the link above to see other relevant comments and links in that thread.
    Also, I forgot to mention that the lower portion of the condenser is actually a subcooler. So when filling with refrigerant, an additional 100g must be added after bubbles disappear in the sight glass.
  6. Mike500
    Mike500 Senior Member
    2,593
    764
    If you are topping off refrigerant, this option might be better;
  7. Mendel Leisk
    38,647
    Just like to add to the "take it to the pros" chorus. The typical reason for needing a recharge is a leak. And AC leaks should be addressed, not patched with top ups.
    And to add to the other chorus, do even need a top up?
  8. Fred_H
    546
    473
    26
    Germany
  9. Mike500
    2,593
    764
    There is no such thing as a "perfect seal." All seals leak a little over the years. NASA uses the most expensive and highest tech seals, but the still leak.
    Unless there is a significant leak down to near zero, there is no harm in "topping off" an AC system.
  10. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Prius (gen2 and after) ac-system has no seals that have to seal against moving parts. Normal ac-system has compressor front seal (it seals against spinning shaft) where almost all acceptable leaking comes from. In Prius (gen2 and after) only acceptable leaking comes from seals where seal has to move when temperature changes. So acceptable leaking in Prius ac-system (gen2 and after) is small fraction of acceptable leaking in normal ac-system.
  11. Mike500
    2,593
    764
    I've worked on auto air for over 45 years. The shaft seal doesn't spin on the shaft. It is the end of a spring loaded ring impinging on a plate.
    No seals? Maybe no "spinning seals," but no gaskets and "o" rings? ALL gasket and "o" rings "weep." Maybe, so little, it will take years for it to be detected.
    So, a "top off" after eight years is normal.
  12. Fred_H
    546
    473
    26
    Germany
    You are both correct. But I would like to expand and quantify your statements:
    There is no harm in "topping off" an AC system, if:
    - it is so low on refrigerant that performance would significantly benefit from a top-up.
    - it is done properly.
    Topping off a system that doesn't really need it does harm by wasting money, time, material, and unnecessarily risking that something could go wrong.
    Doing it properly means using equipment uncontaminated by oil from other systems, purging and evacuating lines to prevent contamination from air and moisture, and filling to within 30 grams of the specified optimum level. Can this be done reliably by an amateur with a refill kit?
    I will venture to guess that the Prius system looses about 1 to 2 grams of refrigerant per year. There is a window of good performance within +/- 30 grams of optimum charge. Assuming that, on average, systems are charged close to the optimum at the factory, then it would typically be about 15 to 30 years before there would be a significant benefit from topping off the refrigerant.
  13. Mike500
    2,593
    764
    Like I discovered in the transaxle fluid level, the fill at the factory is just about 10ml above the low fill level.
    The AC systems are fill just a tad above the minimum fill level with enough to spare for very minor leaks during the 36 month warranty period.
    Given the number of cars produce, filling the systems to optimum level or to fill the system to the top level is not in the interest of the manufacturer. It saves them a lot of money.
    A six ounce top off in three years is actually a GOOD option. I did that to my 1998 Mazda MPV. The AC still functions like a NEW system 16 years later.
  14. Cadenza
    Cadenza Member
    121
    37
    LALA Land
    To do it accurately, don't you need to evacuate the system first and then refill?
