a/c system
Discussion in 'Gen 2 Prius Fuel Economy' started by nhalber, May 7, 2005.
  1. nhalber
    nhalber Junior Member
    83
    Marblehead
    Anyone have any suggestions as to how to best use the a/c system?
    I have had the car for two days and it's great.
    Should I leave it on auto?
    Thanks
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Usually I just leave in in auto and the temp that is comfortable
    In the winter I usually leave it in auto put disable the a/c function so the compressor doesn't run but the temp is still adjusted auto matically
  3. Tideland Prius
    16,159
    Well, since you're giving automatic climate control, just leave it in AUTO :). You can then toggle the A/C function since AUTO works with or without the A/C activated. Note that even though the screen says that the A/C is on, depending on ambient temperature, it may or may not be actually on.
