A/C vent vanes difficult to move left/right
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Apr 7, 2025.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,035
    773
    Virginia, USA
    The plastic a/c vent vanes that let you direct the air left/right (driver/passenger) have gotten to the point where they a sometimes very difficult to move using the "tab."
    Is this a silicone spray fix? Other suggestions?
    Thanks!
  2. Prius_Gnome
    Prius_Gnome Member
    81
    28
    Long Island, NY
    Have you tried removing the vent panels to take a closer look at them? If I remember correctly, the vents are hinged/levered, so maybe there's crud blocking them from moving around. Or a hinge is loose/broken and isn't in its original position, such that you need to push it back into place.
    FWIW, removing the dashboard panels should be a fairly simple job that doesn't require much technical know-how.
